Hunter tool
Starry S Chan
Last week, I posted a question about using a tool very similar Hunter Tool #4. This tool is made by Harrison Specialty. It has a 5/8" round shank with a 1/2" round carbide cutter.
I tried this tool again today and my experience is better than my first trial. On the outside of the bowl, I laid and secured the tool flat on the tool rest and rubbed the tip bevel against the wood. I then rotated the tool until it started cutting and I used the handle to control the depth of cutter. This seems to work but I do not have the same confidence as with either a bowl gouge or the Easy Rougher.
When I used the same technique in the inside of the bowl, I got a bad catch. The reminded me my experience with a scraper until I grounded a negative rake on the scraper. I also had the same problem with a genuine Easy Finisher. With a bowl gouge, I am confident that I will not get a catch if I maintain bevel contact with the wood. With this Hunter Tool #4 clone or the Easy Finisher, I am never sure that I will not get a catch when I make a cut.
I remember watching a video with John Lucas finishing a bowl using the Hunter Tool #4. I cannot find this tool on the Hunter Tool web site.
Starry
