TRUFUEL - an answer to Old Gas in 2 cycle engines?
charlie belden
How many times have you filled your gallon gas jug, poured in the little container of 2-stroke oil, filled your chainsaw tank - and then let it sit for a month or two or six over the rainy season (we don't actually have winter in Sunny California)?
How many times have you left a quarter tank of gas & oil mix sit in your chainsaw for a month or two or six, only to find the next time you TRY and use your chainsaw - that your carburator is varnished up beyond functioning?
How often do you EMPTY your chainsaw's tank if you're not going to use it in the next week or two, or months?
The friend who cut up The Madrone Burl turned me on to a new product that, while $4.99 for 32 ounces, may make all that Old Gas and Varnish Build Up a thing of the past - and maybe let you retire your old gas can. It's called TRUFUEL, 50:1 Gas + Oil, Ready To Use for 2-Cycle Engnies, by Maruyama. AND - it's 92 octane..
No alcohol to dissolve rubber - 2 year shelf life and an optimize oil:fuel ratio. Smells vaguely like GooGone or Goof Off.
Anyone used this stuff? Sounds like something someone shoud've come up with years ago.
Re: TRUFUEL - an answer to Old Gas in 2 cycle engines?
bill Crommett
I have always used premium gas in all my outdoor equipment and have had no problem with varnish, even after months of un-use.
Regular gas is made by "dirty technology".
And its only $32 per gallon.
Terry Quiram
Check your math
charlie belden
Terry:
At $4.99 a quart (32 fl oz), which is what each can of this stuff is, and 4 quarts per gallon - it's $20/ gal., not $32 / gal..
I was dumb enough to leave a half tank of gas in my STIHL - for six months. (I've got an electric chainsaw for home cutting.) The "complete overhaul" price tag for the STIHL was $180. If I'd left even a full tank of this stuff in my saw - for a year - that'd be only $2.50. For as often as I use my saw, that's a pretty good Return On Investment.
This stuff clearly isn't for folks who use their chainsaw regularly - and drain the tank religiously. For me? Well it's worth trying.
I stand corrected. *LINK*
Terry Quiram
Charlie I was basing my comment on an advertisement I saw in my Baileys catalog. I didn't remember that the price was for 6 quarts. Its a lot easier to dump out the fuel and then run the saw dry until the next time its needed. I put the left over fuel from the can in my truck.
Chain saw fuel in a can
robo hippy
I only put premium in my chain saw. Only problem I had with Varnish was when I left the gas can on an outside work bench for a month or so. It got partial sun light, and distilled what was in the can. Saw worked fine till after lunch. Couldn't even pull the rope. $180 or so lesson.
robo hippy
Keith Tompkins
Keith Tompkins
High-test for me too!
