REAL MILK PAINT
Monster Help - Update
Steve Criscenzo
Thanks for your suggestions everyone. They were all a great help.
There were a couple of things that made a big difference. I think part of the problem was that my angle of attack was not correct and the side of the cutter was contacting the vessel. I reground he tip to cut back the sides a bit and move the base up up so my approach angle allowed cutting with the tip of the cutter. All vibrations gone and it cuts like a dream.
A couple of other things I noticed. I was careful to stop and remove chips but because there was a belly in the form, as the vessel spun, what chips remained went to the widest part and that was where is was having problems. Lesson learned, clean chips more often. I also reduced the extension of the cutter out of the tool and that helped as well.
Finally, I was very impressed that Randy Privett contacted me directly to be sure I got it worked out. That is great customer service and most appreciated.
As with any new technique, there is a learning curve but I am very happy with the design of this tool and the results produced.
Thanks again for your suggestions.
Re: Monster Help - Update
Don Leydens
Don Leydens
Glad it's all worked out. I had to do a little fine tuning for the same reasons on mine, too. I love that tool!!!
Richard Jones
Steve,
Glad it worked out, sorry I told you about the articulated version instead of yours. That's what assumption gets me..........
Randy is very service oriented and has helped me out with a few issues, mostly mine!!!
Rich
