Finding centre from inside a big hollow cylinder
GolfSteve in Calgary
Let�s pretend you�re turning a hollow form 6000 mm (19.6 feet) in diameter. There�s an axial rod running through the centre of the vessel, held on the centreline with a guide, but you managed to bend the guide. You�re standing inside the vessel and the bottom third of the vessel is full of dirt, so you can�t reference the bottom of the vessel.
How to you find the exact centre so you can realign a new axial guide? Your toolkit consists of one Chinese wrench, one Chinese hammer, a cell phone, a Beall tilt box (thanks Lee Valley) and maybe a piece of string with a bunch of knots tied in it.
The cylinder and axial guide:
When the machine was built they had a bunch of fancy alignment lasers and doo-dads and lots of guys with big brains running around. Once the ends of the cylinders were installed you can�t reference stationary points outside the machine anymore and all the smart guys left.
I�m throwing this out there mostly for laughs and hoping for a simple solution from folks used to finding centres. I�m sitting in the mud in China with a broken machine and need to figure out how to get the bent guide for the axial rod aligned perfectly on centre to less than ~3-5 mm tolerance. The machine weighs 2800 tonnes, rotates at 4 rpm, and operates at 500 to 740�C (950 to 1400�F).
Cheers,
Steven
(living �The Chemical Workers Song� by Great Big Sea)
ps. After screwing around trying to measure centre when there�s nothing to reference to, I�ll probably weld a stand onto the cylinder with a target on it. I�ll mount a spring loaded pencil onto the bent stationary axial guide, then turn the machine several revolutions, drawing a circle onto the target. If this works then I�ll know how much, and in which direction, to move one end of the axial guide. The other end of the axial guide is more difficult and I haven�t figgered that one yet.
My tools, a Chinese hammer:
And a Chinese wrench:
