Did you know about this?
mjonesrdg
I�ve come to realize in recent months, that re-hydration of dried and warped wood turnings is not a common practice in our community of turners. Have you ever done this?
The concept is simple: When green wood dries, (de-hydrates) cells collapse, the host work piece shrinks and then, �warps�. The shrinkage, typically being unevenly distributed, often results in oval-shaped bowls, lopsided vases, tipped goblets, etc., and often then, considered to be a �failure� and/or not worth trying to save.
For all of the various methods that have been utilized, taught, and written about regarding the control this natural tendency of wood to warp, little has been offered for methods to save the work from the kindling pile when even our best laid plans and practices present unpredicted and unwanted results. It often takes much longer to redeem a wayward bowl than to simply turn another one.
Now, dry wood, when re-hydrated, will swell those collapsed cells, add lost bulk to shrunken areas, and at least to some degree, return to it�s original, pre-dehydrated size and shape. So, as whacked-out as it may sound, sinking warped work into a tub of water and leaving it immersed for a week or so, can give the turner a whole new set of options.
When a piece has warped beyond the limits of returning it to the lathe, having this re-hydration method will again give the turner the option to chuck it back up�turn it thin, add a rim, band or collar or, (insert here your creative ideas). Additionally, cracks can swell shut with re-hydration and can then be glued instead of stitched, filled, or repaired with biscuits.
If you haven�t done this, and should you be inclined to try this road to �bowl redemption�, know that �results may vary� and that your experience and results shared here could lead to an amassed pool of very helpful information. Re-hydration of the turned piece may evolve into design and technique planning with a world of potential.
What experience have you had with re-hydrating wood?
Mike Jones�in Redding, California
