whats the best way...
GaryG in MD
...to keep freshly-cut, wet holly from getting blue stain, or whatever it is that makes it turn dark?
I picked some up at tonight's silent auction. Some is already sealed, but I've got a main stem about 3 feet long and 6 inches in diameter, with a lot of side branches cut off. I can't possibly turn it all in the near term, so I've got to try to save some. How will I have the best luck keeping it light in color? Should I process the log into smaller billets now or just seal it up and keep it cool and dark?
Thanks, Gary
Re: whats the best way...
Richard Allen
Richard Allen
DNA soaking has worked for some folks.
Bill Turpin in WNC mountains
Obtain wood that does not have the blue stain gene in it. Some wood stains no matter what you do. It is best to get wood that is cut for enough time to show that it is not going to do it. Gene is microscopic, it is hard to see.
GaryG in MD
Rick, I hadn't thought of that -- thanks. ...Gary
GaryG in MD
Bill, Interesting reply. I didn't know it worked that way. I thought blue stain was a fungus whose spores are everywhere, and every piece of holly would get it sooner or later depending on storage conditions. Maybe I'm wrong. ...Gary
Gary: I believe it is as much mineral stain as much as anything. The best treated holly that I have ever prepped stained. It was cut and painted the same day, then kiln dried, it stained as much as any I have had. I recently found a piece of firewood, stored ouside for six months. NO stain
Carole Valentine
Holly. My favorite if it behaves. Have turned and carved a lot of it. May stain, may not. I have even had some holly that immediately got a bright red stain where the saw chain contacted it. (No, there was no red paint on my bar or chain!) First time I saw it I thought I had cut myself somewhere! DNA or boiling seems to work to help prevent the bluing for small pieces. Boiling worked better for me. If the tree is stain prone, larger pieces will stain when the inside is exposed to air no matter what you do to the outside. Quickly turning very thin and sanding to dry works sometimes. Two Part Bleach can help with very light stain but won't usually get rid of it entirely. You can always breakout the airbrush! LOL Oh, and I can almost guarantee that you are going to get cracks at every one of those branch junctions on the log. And if you want to spalt it, beware that it goes from spalted to rotten almost over night.
Thanks, Bill...
GaryG in MD
Very interesting -- that's the kind of knowledge I was looking for. Sounds like a crap shoot. Will just have to do my best with it and see what happens. Thanks, Gary
Thanks, Carole...
GaryG in MD
Wow, sounds like you wrote the book on holly.
Lots of interesting facts there. Just what I needed to hear.
I suspected those side branches might turn out to be problematic -- now I know that I'm going to have to "deal with them", when I cut it up tomorrow. Thanks for the warning.
I'm surprised about the boiling -- I wonder why that works. I would have thought it might even make it worse. I've never set up the equipment for boiling, but it sounds like here's yet another reason to do so...
Thanks a lot for your insights, Gary
Re: Thanks, Carole...
Carole Valentine
Not necessarily facts...just my experience! The only thing I have boiled are small billets about 1 1/2" in diameter and I did that on the kitchen stove. Sort of led me to think that the stain must be organic? Six months in the freezer seemed to work too....but it resulted in the wood cracking. Expansion from ice crystals I suppose. I use holly that has stained for my black pieces.
George Van Beynen
Now I will appreciate your holly pieces even more. ;-)
Barbara Gill
My experience has been similar to Bill's in regard to blue stain on Holly. For the most part I rarely have had Holly stain, even when I had to cut up a truck load during the summer.
Now there is a natural blue-gray color in the center of some Holly. This is not blue stain.
I have used denatured alcohol to soak rough turned Holly blanks, even one that yielded a 18" bowl. Those pieces stayed white. Of course I don't know if it was the alcohol or if they wood would have stayed white on it's own.
Thanks, Barbara...
GaryG in MD
Good points and info. ...Gary
