Ziricote Follow-up
Ziricote Follow-up
Ziricote Follow-up
Doug Reynolds in Seattle
I posted a question below asking for alternatives to ziricote which is in the plans for my first ever segmented turning. Gilmer was a recommendation and they do not have a single piece big enough for the base of about 3/4" X 7" X 7". Is it okay to glue up several narrower boards to make the base or, it that going to look bad, or be weak? The other woods are figured maple and bloodwood with maple and black veneer.
TIA, Doug
Re: Ziricote Follow-up
Richard Allen
Richard Allen
Yes it is okay to glue up smaller pieces to make a larger piece. Isn't that one of the principals of segmented work?
Re: Ziricote Follow-up *LINK*
Stuart Johnson
Doug, a 7 inch base is pretty large. You might want to go over to segmentedwoodturners.org for some additional information about bases. Here is one link discussing base size.
http://www.segmentedwoodturners.org/forum/showthread.php?161-Salad-Bowl-bottom-alternatives&highlight=base
The second link is to the home page.
Segmented Woodturners
john lopez
Looked in my wood stash & I found a ziricote blank measuring roughly
5 1/4 x 5 1/4 x just under 2 inches thick.
One edge is waned so there may be some waste on the sapwood side .
The sapwood undulates and is uneven and penetrates to about 1/2 inch.
The rest is dark.
If you can use it shoot me an email .
Maybe I can send a photo so you can have a look.
If you haven't tried this vendor you might find it here.
http://www.anexotichardwood.com/
John
ticklingmedusa@hotmail.com
Nelson
I agree, 7in base is big unless it's 20in or larger vessel. The base should be a solid peice, this is where you go with another type wood.
