Re: Hunter tool
Lyle Jamieson
The John Lucas clip can be found through Mike Hunters Website. www.hunterwoodturningtool.com, go to Tutorial menu, look for Lucas general use video.
You said "similar" to Hunter. All carbide cutters are not created equal. The wide range of carbide quality and presentation angles makes it pretty confusing. Some need to be used for shearing/slicing cutting, some used for scraping only, some good for roughing, some can be used for finishing. If you understand the dynamics of turning you will never get a catch with any tool, carbide or otherwise.
Let me define some things. All slicing cuts must have the bevel support. All scraping cuts must be presented to the wood at less then 90 degrees. It's just that simple. Once you obey the rules you don�t get catches. My "Bowl Basics The Easy Way" DVD is in most turning club libraries. It covers all the foundations needed to turn safe and fun. I use the bowl format to instruct how to have complete control and never get a catch again. I use a bowl gouge from start to finish in the bowl, but the same rules apply no matter what tool you have in your hand.
As most turners realize early on in the learning curve they need some help to improve tool control. It is a lot of trial and error, and the errors lead to fixes that might not be very dependable and create obstacles to fun and creativity. You have turning club members near you that would be willing to mentor you in tool control, just ask. Your question is revealing. I hope your experience with the carbide cutter leads you to greater insights on tool control with all of your turning tools.
