Calling Barb Gill
Calling Barb Gill
Calling Barb Gill
Don at Central Illinois
Your name came up when I was asking for advice on what finish to use for a drinking glass made from walnut. They thought you used CA, but not sure. Please give any advice on finishes for inside of drinking vessels.
Re: Calling Barb Gill
Barbara Gill
Don, I never have made walnut drinking glasses. I have made walnut stems for wine glasses. I would think a "glass" from walnut would be problematic. I am sorry not to be any help.
That's okay. This is the first time I've made drinking glasses. I am a little worried about the tannins in the walnut affecting the liquid, but I will put a disclaimer on it when I give it to the client.
My mistake. Its Barbara Dill. Both of them are in the Richmond Va club with me and I confused who made the drink ware. According to my son, whose memory is better than mine, she bought CA by the gallon and soaked the pieces in it. They bubbled up and covered themselves with the white film. She turned that away and coated them again. At that point they were dishwasher safe. Two guys sharing a brain.
Barbara Gill
LOL I started to ask if it was Barbara Dill who could answer the question.
Barbara Dill
I should read this site more often!! Lots of fun stuff. I do make goblets of all sorts and kinds of wood. I called a manufacturer of CA glus years ago to find out what it is. I knew it has been used in medicine and that it must be non toxic when dried. It becomes an inert plastic...so I have been using the thin CA glue and swirling it in the inside of the cups and goblets after they are dry and sanded. I use 2 hemostats, one with a small wad of waxed paper and one with a small wad of paper towel to sop up the puddle at the bottom of the cup. This must be done with plenty of ventilation and quickly. Wood is insular and can hold hot and cold drinks easily. This is the only finish I've found that is stable and has no taste.
Thank you. What is your opinion of walnut as a drinking vessel?
Barbara Dill
In my experience, walnut is a very wood to use for cups and goblets, as is oak or any other wood, since CA glue soaks into the pores and seals the wood. Do you have specific concerns?? I need to understand your question a bit more. Thanks.
No, I had just heard, or thought I heard, that walnut was not very good for drinking vessels because of the acid or tannin in the wood. But if CA will seal it, that's what I'll use. Again, thank you.
Barbara Dill
I understand...call me if you want..there are many ways to apply CA glue..I've found a way that works for me.
