I use Krylon Fixatiff. It is used to protect pastel drawings. I got that from John Jordan. He uses it on some of his turnings. It changes the color less than any other finish I've tried. On some woods it looks like you haven't applied any finish whatsoever. On some woods such as cedar it still changes the color. Try a test before you apply it so you won't be surprised.
It's the END GRAIN that "darkens", even if you apply deionized water. And with sandblasted wood you expose more end grain.
If the surface were smoother you can rub the piece with a steel or stone burnisher and compress the end grain AND fine scratches to get a pretty reflective surface (shiny) Tumbling with smooth steel shot or crushed walnut shels might work for highly textured surfaces - it the texture is large enough.
Now burnished wood is compressing the wood fibers so they will spring back some depending on the humidity of its environment. BUT - while it's compressed - and the end grain has been semi-closed - a "water clear", non water based coating can slow that down considerably, without a) raising the grain and b) changing the color.
You can make a tumbler out of a five gallon bucket - with lid of course - some roller, gears and chains from an old Xerox machine - and a small electric motor. And if you really like walnuts - that you have to shell yourself . . .
Another source is any of the art suppliers like Jerrys Artorama and Dick Blicks. And another good brand name for "fixative" is Grumbacher which is also non yellowing.
Depending on where you live you can use these guys to get it via internet if you are not near one of the stores.
Thank you Don. It seems I am really getting in wood bleaching with 7 new one started today. Will have to try a number of different one and see what I think I like best .
