Serendipity: the box, and the Hunter...
GaryG in MD
What is that? A movie? A song? A book? Nah, just my afternoon.
Sometimes, things are just meant to be. I bought a new Hunter tapered shoulder tool (Mark St. Leger design) a couple days ago. (Thanks for the quick service, Mike.) My "need" is for hollowing right up under the shoulder of small, flat-topped HFs -- a place I've definitely had problems in the past (read "enlarged hole"). This is exactly what Mark designed it for -- saw him use it in Hartford and have been wanting one ever since. Finally pushed the button.
But my next project turned out to be a tooth-fairy box for my daughter, not a HF. I think you can figure that "priority" out pretty easily. Well, that's all well and good, but I've never made a box before (well maybe one). So I'm into OJT.
I picked a nice piece of very dry walnut sap wood (turns a very nice color when finished) and got to it. Everything is going along great. I get to the critical point -- the fit! I don't want to jam a scraper down into end grain (I hate sanding), so I figured I'd sneak up on it from behind -- with the little Hunter coming across the domed inside, center-to-edge. Perfection! I had no intention of using it for that cut when I bought it, but it's a natural. No tear out -- smooth as a baby's butt -- I started sanding at 220, and, frankly, I'm not sure if I wasn't making the surface rougher! Easy to get just the right size for a good fit (tight enough so the bottom comes along when picked up by the top, but not a "pop", because that might send the teeth flying across the room!).
Great tool and unexpected application. That makes a good day of turning.
So, what do you'all use for cutting into end grain to size the box tenon so that no significant sanding will be required?
...Gary
Re: Serendipity: the box, and the Hunter...
Re: Serendipity: the box, and the Hunter... *LINK*
The various Hunter tools are my box interior tools. They are also the tools I go to for undercut lips on bowls either inside or outside. Someday I'll have time to do a video of that cut. I use the #5 or #4 hunter for that cut. However the new back tool is also wonderful for that.
for those unfamiliar with the various mini hollowing tools here is the video I did. I hope it explains what they are.
http://www.youtube.com/watch?v=FFW5ODChWkI
Mike Stafford
Mike Stafford
I use a sharp parting tool or my skew to size the tenon particularly after I have jam fit the lid onto the tenon and all I am trying to do is get that nice suction fit.
Of course it is essential that I have cut the sides of the lid, the female part which overfits the tenon parallel. I do that with a square scraper sharpened along the side and the left edge. My scrapers are not square as they are ground with the cutting edge square at the left corner but angled slightly toward the right side so that the left corner makes contact first with whatever it is cutting.
I use my #3 Hunter tool to cut the inside top of my lid and if I am careful I get a finish that requires little or no sanding. On the more dense hardwoods the finish off the tool requires nothing more than a swipe or two with 400 and some 3M non-abrasive pads to get a nice shine.
But where I love my Hunter tools the most is when I am undercutting the body of one of my chubby squat boxes. After the initial hollowing for rough depth with a gouge I switch to the #1 tapered swan neck to begin the undercutting. If I do this correctly the amount of sanding that will be required is greatly reduced. I follow that up with alternate uses of the #3 straight and #3 swan neck cut the final bottom depth and shape the main portion of the curved interior surface. The Hunter tools literally leave a polished/shiny surface if my tool control is consistent and I ride the bevel properly. The #3 swan neck allows me to blend the bottom with the sides and undercut.
In the past when I used the #3 swan neck for the undercut and shaping of the inside I would get chatter because the cutter would be engaged with 1/2 or more of its diameter making it want to self feed. By doing the majority of undercutting with the #1 tapered swan neck I don't have the chatter problems and sanding is held to a minimum.
Thanks John and Mike...
GaryG in MD
Good info -- it was valuable to hear it and to watch the video again. Thanks, Gary
