Woods with low tannic acid *LINK*
Craig Daymon
If you want to try fuming and feel that a low tannic acid wood is what you want to fume, you can find tannic acid, I believe in a dry, powdered form, in the grocery store in with the canning products. Mix some up with distilled water and paint it on the piece before fuming.
I've fumed white oak, red oak and American chestnut with great success using household ammonia. (Same stuff you bought at the grocery store.) Yes, it will take longer than blueprint ammonia, but it is SO VERY MUCH safer. I firmly believe one very important factor is using an air tight container. I have a large, 40 gallon Igloo cooler that works great for most turned pieces.
As an example of what can be achieve with household ammonia and the proper container, I remember watching David Marks build a piece of Mission furniture out of white oak and fume it with blueprint ammonia in a framed box he tented with plastic sheeting. After, I think, 8 hours of fuming (done outside), his results were far less impressive than a white oak candlestick I fumed for about 12 hours. I believe this is because of the difference in the air tightness of our fuming containers as 8 hours is a LONG time to expose a piece using blueprint ammonia.
The candlestick is in the Shop Shots, number 348. I've posted a direct link below. Keep in mind, as stated in the description, that there was actually a much greater difference in person between the unfumed piece and the candlestick than what is shown in the picture.
If you can get results like that with household ammonia, why take the risk of using blueprint ammonia, which is very dangerous.
Fumed white oak candlestick, Shop Shot 348
