Kaput coring blade
Kaput coring blade
Kaput coring blade
Jorge Castaneda
Today I broke the blade used the most of my Kelton rig, the middle curved from the standard set.
Is there life after death? Shall I jump to buy a new one or this can be salvaged.
I was to post a picture, but the forum software is not as usual, a bunch of features are missing, like the browse to load a picture from disk.
Re: Kaput coring blade
Greg Haugen
Jorge,
Sign in to your profile, or create one. It will be there then. If you still have problems, let me know.
Amazing service!!
Jorge Castaneda
Kel Mc Noughton contacted me already about my problem!
Much appreciated Kel.
Jorge Castaneda
Thank you Greg, i"ll do it tomorrow first thing.
robo hippy
I am guessing that it was bent beyond being able to bend back into proper shape. That is the most common thing that happens with extended use, or a few good catches, so bending back isn't too much of a problem. Kel is a good man to deal with.
robo hippy
Jorge Castaneda
Reed,
It is not bend, I was going into a maple rootball, just the very tip broke, must have hit gravel.
Greg Haugen
Kel is a great person to deal with. Glad you got it taken care of.
I've seen stones that were in the 6" diameter wrapped up in root balls. Boy that would sure cause some havoc on the lathe.
George Van Beynen
Or leaving the lathe at 600rpm. :D
robo hippy
Well, Jorge, that is one trick with the McNaughton that I have never done.
robo hippy
Ken Vaughan
Kaput coring blade - Rettipping
Ken Vaughan
I think Mike Hunter has retipped some McNaughton blades -- that is an alternative to replacement.
Re:  Kaput coring blade - Rettipping
He does and it works great. I have one. They are diamond shaped carbide cutters and man do they cut.
Thanks Kel!
Jorge Castaneda
I followed your suggestion and did grind away and the blade is back in business.
Robo, don't try it it is not fun.
Thanks everybody
