REAL MILK PAINT
Oneway coring jig
Oneway coring jig
Donna Parrillo
Oneway coring jig
Donna Parrillo
I just ordered a Oneway coring jig and am waiting for it (they are backordered). I would like to rough prep some bowl blanks ahead of time, but my question is what DEPTH bowl blank do I need to start with? I plan on turning a 14" bowl, then core with the 11.5" and 9" knives. Any tips on use would also be greatly appreciated.
Donna
Re: Oneway coring jig
Bill Neddow
Donna, it will work on any depth of bowl blank. You adjust the depth by how close you put the tool base to the block of wood.
Richard Allen
Richard Allen
You are going to love the easy core. The learning curve is very short. Follow the setup directions and you will be successful every time. Pay attention to the sharpening instructions. The smaller knives should be sharpened every 2 cores. The larger two knives should be sharpened after each core.
Coring green wood is a pleasure, You can core bone dry very hard wood, I have cored Jahra burl easily, though more slowly than green maple.
The deepest bowl you can achieve with the 11 1/2" knife is 5" (add 3/4" for the kerf and 1" for the thickness of the 14" bowl). So a 14" blank that is 7" deep will result in the maximum bowl sizes. I like to have 1 1/2" of depth for each bowl so a minimum of 4 1/2" for the 14" blank. You can core with 3/4" if depth for each knife but that makes the process questionable and experience will help working to such tight margins.
Donna Parrillo
Donna Parrillo
Thanks Bill and Richard. This is the information I was looking for.
Donna
robo hippy
The number of cores you get is determined by your turning style and how thick the starting blank is. If you are turning green to final thickness, then a 1/2 inch thick bottom is fine. If you are twice turning (green wood, leave thick, dry, return) then leaving it a bit thicker is preferable, though the bottom does not have to be as thick as the sides. You will lose the kerf, and some depth for whatever foot you will be turning on the bottom for remounting. I generally will get 3 cores from a 6 inch thick piece, and I green turn to final thickness. I could get one more core, but the last bowl is generally so small that it isn't worth the effort.
If I was using the Oneway, I would prefer an abrasive disc, or a belt sander for sharpening rather than the grinder wheel. Just easier, and I was a bit intimidated by holding that tiny cutter up to the grinder wheel. They do make a small jig which takes some of the pucker factor out of it, and it is handy. They also used to include a push pin in the kit. You need it to clean out the hex bolt to remove the cutter from the blade.
It is a nice set up, and rock solid even with the largest blades. I still prefer the McNaughton though.
robo hippy
Bernie Weishapl
Donna I just cored a 13" X 5 1/2" elm blank. I got a 12 1/4", 9" and 6" and this was my second try. It did have some knots thus the slightly smaller sizes. Was pretty happy with them. If I were doing green I think I would want the depth to be around 7" for sure.
Donna Parrillo
Donna Parrillo
Thanks Robo, I appreciate the tips.
Donna
Donna Parrillo
Donna Parrillo
Bernie,
This is green wood which will be twice turned so I will err on the larger size. But this gives me an idea of what size blanks to cut. Thanks for your input.
Donna
Dale Bonertz
Donna,
Contact my friend Larry at http://www.foxywoodz.com/. He is a great guy and has developed an easy method to setting the oneway up for coring. I am a Mcnoughton user so we get to rib each other on occasion. I just spoke with him and he is more than willing to help.
Donna Parrillo
Donna Parrillo
That's a big help Dale. I will contact him and pick up some helpful tips.
Thanks, Donna
