Thread size question on Jet Mini Lathe Part
Rob Wallace
Rob Wallace
Does anyone know (or can confirm?) the threading size for the tool rest post locking lever and the quill lock lever for a Jet 1220 lathe? Is this 'standard' or metric threading?? Nothing in the manual shows what the threading is for these two adjustment levers. My mini lathe is stowed at present, so I can't retrieve the parts to test the threading, which I think might be 5/16-18, but I'm not sure...
I stripped-out the teeth in the tool rest adjustment (spring loaded) locking lever while doing a demo last weekend, and need to get a replacement. Those parts listed on the Jet parts web site seem to be quite overpriced, particularly when the 'shipping and handling' fee is factored-in.
If I am to pay a premium price for a replacement part, I'd rather get an industrial quality adjustment lever from MSC or Reid Supply, rather than the OEM replacement part that has been proven to be less than reliable. Has anyone been down this road before and knows what the threading is?
Thanks in advance for any help.
Rob Wallace
Re: Thread size question on Jet Mini Lathe Part
Rich Egan
Rob:
I had a similar problem with my mini, an older Steel City. The first lever stripped out inside, so I swapped with the one in the tailstock, which is the same size. Then I stripped that one out. I think the threading was probably metric. Like you, I wanted something more robust. I found a star-shaped knob with a 3/8" post, so I just drilled and tapped the hole in the banjo for that size. Works great. In a pinch, I can go to any hardware store and find a bolt that will thread in there.
Stay cool,
Rich
