setting up new Makita 1016l miter saw
I bought this to help out with segmented pieces and also to make more room by selling the radial arm saw and miter saw. I got everything adjusted except the laser. I'll do that later. I set the saw for what I think is 11.25 degrees. I'm taking a break before I go out and cut 16 segments to see if it's right.
How do you all set your saws for something like this. I'm trying to figure out a way to accurately reset it each time. I don't think putting scribe marks on the saw will work. In the Past I've tried cutting an extra segment and using that as a gauge but with very mixed results. Maybe it was the quality of the saw/blade/user, etc. I hope to upgrade all 3 of those. I am going to make a test segment out of MDF this time around to see if that works. I was hoping I could find some way of measuring between 2 known points with my long dial calipers so it would be repeatable within a few thousands of an inch but so far haven't hit on any good ideas.
I started gluing up a board as a final bowl project once I get the tests done. I haven't made one of this type of segmented bowl for about 15 years. It should be fun and will bring back some memories.
I'll give a better review of the saw after using it for a few weeks.
Re: setting up new Makita 1016l miter saw
Dave Paine
On my old radial arm saw, I used a 90 deg template. I would check that the blade just touched a tooth and then moved the carriage back and forth to ensure the tooth was touching consistently.
With your laser, I think you have another option.
Assuming you have calibrated the fence to be 90 deg with the blade, and can draw the angle with sufficient accuracy on the piece of e.g., MDF, I would put the template under the blade, turn on the laser and adjust until the laser is in line with the laser.
You may find this easier if you draw two lines separated by the thickness of the laser line. Should improve alignment accuracy.
Good luck. I want to try some segmented work in the future. My saw does not have a laser, so I may have to make a cut groove in a template for my alignment check.
Richard Allen
Richard Allen
Once you get the angle right.
MDF or plywood that is 1 1/2' long, 1' wide and 3/4" thick.
Set the board against the fence to a repeatable stop on the fence.
Now plunge a cut slot in the board. The plunge should be 1" away from the fence and slightly longer than the blade fully engaged.
Next time you want that angle. With the blade in the slot on the board, adjust the angle until the board sits against the fence and against the repeatable stop.
If you can have repeatable stops in 1" increments you could make a series of increasing angles so that one board could be used for most of the segmenting angles.
I played with 11.25 degrees today and had a little trouble finding it. I didn't spend a lot of time. I knew that would be one of the harder angles. I got close. The cuts are clean. I was cutting 2 1/2" wide plywood. It was off just a hair when I had to quit. I cut a piece of MDF clear through to give me that angle so we will see if it's repeatable in a few days when I get the time to play more seriously.
On the down side the dust collection port is just about useless. Without a hose in place you canclearly see that dust is going on both sides down below the port about 6 to one over through the port. This doesn't change very much when you install the dust collector hose. I'll have to build a collection system around the back.
Jorge Castaneda
John,
as the dust making moves around, collecting it is hard, a friend has a fan blowing from the front of the saw and a big plywood contraption on the back with the suction right in the middle.
Don Evans
I think Richard has the right idea except for more accuracy I think you need a wider board. I would use mdf, for stability, but a piece that is 6" minimum and not cut it all the way. This way you can lay the blade down in the cut then raise and lower to see if it is aligned correctly.
As far as finding the angle accurately, I've grabbed up every type of digital guage I could when I see them on sale. One is the little square box for setting 0 and 90 deg mostly and a digital angle finder, one from Lee Valley way back year or so. They together have improved my ability to set things up better than anything.
LASER'S -- so far in woodworking they aren't worth the money. Pretty much a joke IMHO, because the light line is just too wide for accuracy, what I call accurate anyway. The one's on drill presses are the worse yet, the problem is the lights themselves are too close to each other and way way too wide.
Remember when we complained about a sharp pencil line wasn't accurate enough and here we are going backwards with a line that is much wider than that pencil ever was.
Spend the $50 for that digital angle gauge and you'll never regret it John.
Also for this work you might consider a Frued glue line blade, may help a little more.
Don
Don which digital angle gauge are you talking about. I have the Wixey (sp) and it won't the angle of the saw blade. It will measure tilt. I have used it to set the angle of my miter gauge but I do that by laying the fence of the gauge on the table saw with the sliding arm hanging down. Then I can adjust the angle of the sliding arm. I don't think it's practical to lay my miter saw on it's side. :)
I tried zeroing it against the fence and them placing it on the blade and I do get a reading but it's not even close to accurate.
Re: Cutting segments
bill Crommett
John: This has nothing to do with a miter saw setting, because I use home made jigs. My second best tool for making segments is my carpenter's square.
I cut 4 segments and use the square for alignment and then tweek the setting and cut 8 segments and justify with a straight edge. If it is REAL close I use the sanding disk for the final adjustment. The bigger the test scrap boards, the easier to tweek for accuracy.
Bill that's what I'm trying to get away from. That's how I've always done it before. I built a jig for may table saw and at least half the time I can glue up a ring in all at once. The other half I glue up 180 degrees at a time.
With my old system I divided my rings up so I could check them at 45,90 and 180. That sucked. It was worse when I tried to do compound miters. I figure the new saw won't be accurate enough to give me a 12 sided compound miter without have to do at least the 180 glue up, but it might. My friend Don Russel does it.
I have set up my disc sander to do a couple of miters but have never tried to do compound miters that way.
I'm going to find out shorly. I have to do a project that has a 12 sided compound miter. So I'll be cutting up lots of 2x4's until I figure out a way to do it close enough to at least do 180 degree glue ups.
Don Evans
John:
I'm talking about a protactor type, the one you have sounds like the inclinometer a square box type?
Look at this one, it is only $20.00:
http://www.leevalley.com/US/wood/page.aspx?p=64278&cat=1,43513
Mine is different than this one but works the same, put the edge of the blades on your table saw (or any know flat surface) make sure both arms are touching table and then zero out the meter. Then move one arm till you get your 11.5 deg reading.
Place one arm on miter saw fence and bring down your miter blade and use the other arm of gauge against the side of the blade, try not to touch teeth. Doing this you can set the angle you want on the saw. Use it to also make sure the saw is really 90 deg when set at that stop point.
I noticed this particular gauge is only accurate to .3 deg but you can find better one's for just little more money.
Using the protractor type and the inclinometer type together you can check the accuracy of your set and also can learn which way yours is off, it could be on the money as well as off .1 deg.
Don
