New Vacuum Issue and Solution
Stuart Johnson
I had a new (for me) issue pop up on a vase yesterday. The vase was done with the exception of the base. I used my vacuum chuck as a jam chuck and took care of all but the nib. I then turned on the vacuum and went from a good grip to next to none. I had left it just thick enough so some void were not cut through. The vacuum was enough to pop the very thin bit. No problem, I wrapped it with stretch wrap and got a good vacuum. I cleaned up the bottom gave it a final bit of sanding but when I took it off there was a pressure ring showing around where the chuck fit. I had visions of trying to hand sand it but have never had any real luck in sanding out flaws. Then I remembered an old Roy Underhill show where Frank Kleus made a water tight box by creating a dent, planing it smooth and then wetting the edge. The dent popped out and created a ridge to seal the box.
Rather than doing any sanding I wiped the entire vase with a wet towel getting it very wet but not soaked. This morning the pressure ring is gone. I will need to give it some hand sanding and don't know what will show when I apply the final finish but at least one issue is gone.
