A55 Smoothing Plane
Things I Learned Today About Reading Wood
charlie belden
THE Wood Whisperer of our turning club was over this morning to help decide how to cut up the redwood root burl slabs I've described in earlier posts. Starry, a turner from West Bay Woodturners had come over to see the slabs and pick up some tips on reading wood. Here are some things I learned from this hour and a half opportunity. (Much of what follows may be very obvious to old hands at this - and not worth mentioning. But not everyone is an old hand at reading wood - me for example)
SIDE WALK CHALK
Blackboard chalk is pencil diameter, kind of hard, brittle and comes
in WHITE (you CAN find other colors - but it�ll take some hunting).
Side Walk Chalk is fatter, softer, not brittle at all and comes
- in colors (white, blue, red, yellow and maybe green).
Colors are handy with stuff like this redwood because you can mark on one face where there are voids and indentations on the opposite face. This lets you know where the wood is thinnest - and work around those areas. Another color can be used to mark out the outline of a bowl, plate, platter, hollow form, box or whatever. A third color can be used to mark cut lines for chainsawing.
WHEN POSSIBLE GET AT LEAST ONE FACE, SIDE OR END SMOOTH
Where there are �flat� surfaces - removing chainsaw marks, with a belt sander, random orbital sander and/or a hand plane enables you to see the figure in the wood that might not be obvious on a chainsawn face. The more of the wood you can see on the OUTSIDE the easier it is to figure out what�s going on INSIDE the piece of wood. And when you have a good idea of what�s going on inside - you can use that information to decide how to orient a piece in the chunk of wood - or figure out what form would best used the chunk of wood.
DRY WOOD SOUNDS DIFFERENT FROM WET, STILL NOT DRY WOOD OR HIDDEN PUNKY WOOD OR WOOD WITH HIDDEN VOIDS
While turning one of the slabs over it got dropped - and THUNKED when it hit the driveway.
Jim (the wood whisperer): �Man this stuff is DRY.�
Me: �Yeah I know it�s dry.�
Jim: �No, listen. Really dry wood THUNKS different from wet or sort of dry wood. And if there�s punking wood inside, thunking around on the outside will sound different when you�re over punky wood you can�t see - or voids inside.�
Tapping can tell you things - if your listen - and can interpret what you�re hearing.
WHAT YOU SEE JUST UNDER THE BARK CAN TELL YOU A LOT
The bark that had been on the outside of these slabs is long gone. The surface that had been under it, now exposed, albeit quite weathered, gave strong hints of the rippling figure behind them. Little pointy bumps indicate probably �birdseye�.
DAMPEN SURFACES WITH WATER TO �POP THE GRAIN� - EVEN IF A SURFACE HAS ROUGH CHAINSAW MARKS ON IT.
I spent hours with coarse sandpaper In a ROS to see the figure in a face. A 15 second spritz from a spray bottle would have revealed the same information - though not as clearly.
NATURAL SURFACES CAN BE LEFT - AND BECOME DESIGN ELEMENTS
When we think of Natural Edge, it�s usually Leave The Bark On (the rim). But with these slabs, there are rippling weathered surfaces that are on the outsides of pieces on some that could be left and really add to the look of the piece. Working out a form and orientation to keep them may take some head scratching, but the results can be well worth the time and effort. Same goes for pockets and even voids.
ONE BIG NICE PIECE RATHER THAN TWO, THREE OR FOUR SMALLER NICE PIECES MAY NOT BE THE BEST CHOICE.
The temptation we all seem to succumb to is BIGGER IS BETTER. If there�s an infinite amount of really nice wood that may be true. But when there is a limit on the amount of nice wood, sometimes more but smaller pieces is a better use of nice wood.
THE MORE FORMS YOU HAVE EXPERIENCE WITH THE BETTER THE CHOICES MADE WHEN IT COMES TO CUTTING BLANKS FROM LARGER PIECES OF WOOD.
We tend to see what we want to see, and the more familiar we are with a particular form, the more apt we are to see just that form when making blank cut decisions.
THE BEST PIECES START BEFORE THE ROUGH BLANK IS CUT
John Jordan, and many others, point this important fact out in their demonstrations but it�s worth repeating.
WITH BURL WOOD YOU HAVE MORE OPTIONS
Since �end grain�, �side grain� and �face grain� because the grain runs in every direction and keeps changing - orientation can be where ever you feel you want it.
If there�s �birdseye� in the wood you have to decide if you want them parallel to the axis you plan on turning on, or 90s to that aixs. The former will yield round or oval �eyes� when looking INTO the piece, the latter will put the eyes on the front and back or left and right SIDES of the piece.
BURL WOOD WILL SOAK UP A FINISH ALMOST AS FAST AND AS MUCH AS END GRAIN WILL.
It�s tricky to build a finish on burl wood because it soaks up finish like a sponge
Have YOU got any insights for what to look for and why BEFORE taking a chainsaw to a larger piece of wood?
