clear filler?
nick
What do you recommend for filling small voids? Most epoxies seem to be yellow. I need a small quantity of clear filler.
clear filler?
nick
Casting Resin
You can get them at hobby shops likes Micheals or Hobby Lobby. However it's not cheap but it does dry crystal clear. Getting the bubbles out can be challenging. Also containing it in the side of a vessel can be a challenge. You may have to build a dam or some sort. I've used clay. You can often put masking tape on the backside if the hole goes all the way through and then if your lucky orient the bowl so the hole is straight up. Helps to have something like the Bestwoodtools carving jig for this.
Re: clear filler?
Richard Allen
West System epoxy with the slow hardener.
The resin is clear, it's the different hardeners that are more or less amber. The slow hardener is the clearest of the bunch. Some might call it gin clear.
The casting resin that John mentions is water clear. The hardener is applied by drops. Getting the correct ratio of resin to hardener for small quantities of the mixture can be a little challenging.
There is an investment in either the West System or casting resin. There is also an experience curve with each approach. To achieve predictable results you will need to work with the stuff for several projects.
Re: clear filler?
What I've started doing for small quantities is measuring using a small electronic scale. I just measure out the quantity of A that I want. Then put the ratio formula into my calculator to come up with how much B and add that to the total. This has worked really well for West System epoxy. Haven't tried it with other brands but don't see why it won't work. I had the scales left over from my photography days.
another good clear epoxy is System 3 mirror coat that you get at Woodcraft.
Thanks a bunch NM
nick
Re: Thanks a bunch NM
steve worcester
The clearest of clears I have seen is Polyteks Polyoptic line of resins. Not cheap, but clear enough I can cast and turn clear vacuum chucks and still see the laser dot with little distortion.
http://www.polytek.com/cart/index.php?target=categories&category_id=242
Re: clear filler? *LINK*
Dick Coers
Penturners recommend Alumilite for filling wood. It is a urethane that does not shrink like polyester resin and will stay tight to the wood.
water clear Alumilite
