THE WOODRAT IS BACK!
WOODBURNING TOOLS
WOODBURNING TOOLS
WOODBURNING TOOLS
Alan T.
I'm thinking of burning some of my bowls and platters. Can anybody advise what tools you'd need for this. Any ideas about tools and/methods appreciated. Thanks
Re: WOODBURNING TOOLS
David Walser
I usually wait until winter and then burn my bowls and platters in the fireplace. (My motto is: from firewood to much smaller firewood.) I suppose you could burn them outside if, like here in Arizona, it's too hot to burn them inside -- but be sure to check with the local authorities to make sure you comply with any open burning ordinances.
As for tools, my wood is usually pretty dry, so I can get it started with just a match and a wad of newspaper. If your bowls and platters are still a little green, you might want to let it dry before burning it or try one of the paraffin fire starters.
Of course, you might want to get another opinion or two. I suspect you're overreacting. While the bowls and platters might not be up to your standards, others might like them just fine. This doesn't always work. I'm burning mine based on the opinion of others...
Hope this helps.
Your bad David
My suggestion is to buy the best one you can afford. I bought one of the really really cheap burners ($15 variety) and of course thought wood burning was a complete waste of time. Then years later I bought a bottom of the line Colwood. (about $85 I think) Now burning seemed like something that might actually work. I did some fun work but still could not sign my name or get a consistently thick line. I gave that one to a friend and bought an Optima (I think it was about $139). Wow what a difference. It has to do with recovery time and the quality of the pens. I believe from what I read that Razortip is also an excellent burner.
I think what I'm saying is the learning curve is greatly reduced by a good tool so buy the best you can afford. It will make a difference in whether or not you enjoy burning.
Richard Allen
Richard Allen
I tried to do this on my own and ended up buying more stuff than i need as well as doing poor work.
I took and "Intro to Woodburning" class at Woodcraft. Made a HUGE difference. I went from burning a mess to being happy with my results.
If I had signed up for the class first I would have saved a lot of money on tools and I would not have destroyed so many of my turnings.
Get some hands on instruction and follow their advice.
There are several burner units on the market which all work well. Detail Master, Burn Master, Optima will all perform well. Pens are a bit different. Detail Master are good heavy duty pens, Razortip are lighter duty and provide finer detail, Optima has good pens but are not as widely distributed. A small skew tip pen like the Detail Master 1-A is the pen I use the most.
Don Evans
Alan:
I got into this about 20 years ago and now are using a Detail Master which had one port on it. I modified it so it has 2 plug in ports. If I were in the market today I would go with the BurnMaster unit and make my own pens. I've got 2 pen's I made and i think the instructions on doing them are on this site somewhere.
You don't really need a lot of tips. The tips are determined by what you want to do, you can start with a 1A and you'll also want a 6A or 6B. The 1 as stated is a skew for thin or wide lines and the 2 called 6 are called writing tips. The 6A is wided gauge wire than the 6B so if you are only going to get one of those get the 6A for signing and you also use it for drawing things.
One thing that is confusing that sellers of these things don't tell you is that the 2 port models will ONLY heat one pen at a time. The second port is just for convenience. You have to throw a switch to direct the unit which pen to heat. It only takes about 5 seconds to heat a pen.
The are 2 different type of pyro done by woodturners, one is woodburning or pyrography in the normal sense and there is branding. To me pyrography is making a design that looks like a picture of sorts, the people that are really good at this need to learn shading which turns a simple burn into something really great. Branding is where you turn the wood to charcoal completely in an area. A great example of both these are Molly's work.
ck out www.treelineusa.com and www.cherylddow.com
Don
Don Evans
Forgot one very important detail. Make sure the unit you get has minimum of 100 watts and you'll be happy and able to do any form of pyrography you want too.
The burnmaster has 130. Detail master when I got mine was 100 watts.
Don
Alan T.
Thanks for the info guys. I just want to add some interest to my turnings and this seems the way to go and looks fun. I appreciate all the detail in your posts.
Re: WOODBURNING TOOLS *LINK*
Jeff Willaford
For what it's worth... my Nibsburner "Best of Show" model heats two pens with independent controls. I don't have much experience with it but it seems to work fine for me. Nibsburner doesn't show up much in the turning world but seems to have some popularity in the decoy carving arena.
No affiliation... just happy with mine.
http://www.nibsburner.com/
Don Don't forget about carving with pyrography. This is how Dixie Biggs gets relief on her flowers and I believe Jacques Vessery does the same. It is somewhat difficult to undercut a leaf with carving tools but very easy to do it with a hot knife. Of course you have to clean up the burn or paint over it but it is a very useful tool. The new 3M sanding stars make clean up fairly easy.
Steve Kubien
Steve Kubien
I have a two-port Burnmaster and really like it. Easy to control for finer work ( signing your name and other stuff I'm not talented enough to pull off) and loads of power for branding ala Molly Winton or Graeme Priddle.
Re: Your bad David
Dick Wilson
I have the medium priced RazorTip. It works after a fashion. What I don't like about it is that the various tips are more expensive than other models, sometime a lot more.
Just took a class with Julie Bender
Ray - Middletown, In
and it seems most of the high end burning folks use a Razortip. The other brands mentioned here all have fans also. Mine is a Colwood and seems to work ok, but then I barely know what I'm doing with it.
Ray
