"Dualing" Banjos (Deliverance...
Leo Cuellar
Leo Cuellar
from injury? Maybe not, but the first test of concept worked well.
Hi Everybody,
John's quip of "...two if by sea" on the 4th stuck in my head & reminded me that I had some spare parts to work with :D So I cobbled together some parts to make a face shield that incorporated the extra banjo that I now had.
So, here are a few pictures of the first iteration of this device for those of you that like to tinker as well as turn.
I've never actually had anything other than shavings and bark fly back at me. Everything that came off simply fell to the floor & rolled away from me. It wasn't hard to get something to fly back at me once I deliberately loosened the jaws of the chuck and spun the lathe up to 1300rpm. Then I took my largest gouge & shoved it into the side of the vase & BANG right into the shield. I also took several heavy swings at the shield with a dead blow hammer, while I did get the shield to twist a little, it didn't break.
Adjusted properly it provides great vision & ample clearance for your tools. Did I mention that NOTHING heads for your face? Next version will have a pick up point for dust collection or port for a fan to hook up & blow the dust away. I'll probably try curving it to get more clearance and add an upper support bracket to tie it to the main post more securely.
Another possible route is to attach a rod (at the ends only) about half an inch out from the side of the lathe bed for the entire length. Build your shield post onto "tee" fitting with suitable bracket to keep it from flopping around & down. then you'd have an easily adjustable shield that wouldn't take up bed space.
I realize this won't work for everybody, but it might give some of you that extra margin of safety you've been looking for.
Safer spinning!
Leo
Re: "Dualing" Banjos (Deliverance...
Don Leydens
Don Leydens
That's some "cobble" you've done. Wear it in good health.
Well done,
Don L.
Henry (Raleigh, NC)
While I don't have an extra banjo - that looks like a device worth acquiring one for.
I am not certain I can follow your "alternate" explanation. Do you have a sketch or any other way to describe that?
Thanks for the innovation! I love creative thinking that results in a simple and effective (safety) device.
Henry W
More Details Please...
Ed Lason
Our club is looking for ways to protect the turnner as well as the audiance when doing demos. What is the sheild made of?? Did it come with the metal frame?? Looks like it is about 1 foot square. Thanks for sharing.
Leo Cuellar
Some drawings & additional thoughts
Leo Cuellar
This first sketch is of possible attachment for the first alternate method I proposed. Not really an elegant solution, but might be what someone wants, would probably be great for spindle turning...
Could be made of pipe or round stock, welded, threaded or even drilled & tapped to attach to the angle iron end brackets, that would then bolt to the side of the lathe. This has the flaw of not being adjustable for width of turning. This could be overcome with a more complicated bracket near the shield but probably not worth the effort.
Much better would be this third idea for mounting that hit me while I was drawing the previous one.
Best, would be to make this out of square tubing as that would keep the shield support in an upright condition. Box tube one size larger than slide would be needed for the supports that would bolt to the bottom side of the ways and for the base of the shield support. Angle iron welded to the supports on one face would provide a point of attachment to the lathe. Drilling an appropriately sized hole, a flange nut or block of metal suitably drilled & tapped welded to the side of the support tubes for attaching a locking bolt. The railing could be assembled by bolting or welding after sliding on the shield support base. The base should probably be drilled & tapped for a locking bolt as well. This setup would allow front to back travel & keep the bed of the lathe clear.
Guess I'll be going into town later to buy some box tube :D
Have fun every body!
Leo
Leo Cuellar
Re: More Details Please...
Leo Cuellar
Hi, Ed. The shield is roughly 12" x14", just happened to be the largest chunk of plexiglass that I had laying around. The metal frame I built myself out of 1/2" x 1/8" angle iron and 1/2" x1/4" flat bar.
I'm sure it wouldn't be too hard to make a shield from a full sheet of plexiglass to protect an audience. Just use thicker plexiglass and a more substantial steel frame. Make a large flat base that could be weighted down (perhaps with some log rounds) or even bolted to the floor for extra safety.
Mike Stafford
Mike Stafford
Leo, I mean no insult by saying that at first glance it reminds me of a sneeze guard at a restaurant salad bar.
If there was some way to mount a piece of curved plexiglas on a swivel attached to a banjo on the other side of the lathe that could be flipped up and down. Of course it should be able to locked into position when in place to shield the operator.
PM 3520's came with a safety cage that operated on the same principle but I have never seen anyone use one except to hold tools and other things.
Keep working on it. It is a good idea.
Leo Cuellar
Achoo!!!
Leo Cuellar
No umbrage taken, Mike. I put the idea out specifically in the hope of receiving constructive feedback just like yours. A very good idea you've given me about mounting from the back side. The new attachment method I've worked out would allow that with out any additional modification to the new base frame. A curved shield is in the works as well as an end plate which would help reduce the risk of injury during hollowing operations. A flip up mount is feasible as well. One design problem is that in making something "too adjustable" is that one has no control over how well people tighten the fasteners. I would think that it would need guards sized for specific diameter ranges depending on lathe capacity and project size, to keep a smaller piece from ricocheting around & out of to big a guard.
Thank you, for taking the time to respond, Mike. With more help like yours, I think it just may be possible to come up with a design that people would use.
Leo
Re: Achoo!!!
I think it's a great idea but worry that the clear shield will get so cloudy you won't use it. Especially turning really green wood. Perhaps the same thing with a wire mesh like Hardware cloth. Of course that will get shavings hung up in it and make it hard to see around as well.
Leo Cuellar
Rainex?
Leo Cuellar
Yeah, John, I don't think it is possible to design something that will work in all cases. I currently turn mostly dry wood, so I was thinking that making a place to tie in a dust collector or fan would take care of most of that. Wet wood is a whole 'nother problem. Of course it would be less prone to splintering so maybe a wire cage would be best for that situation. I'm not sure how large hole expanded metal is available in, but I'll look into that as well. I don't have a chainsaw so getting a hold of wet wood is a problem for me now. A small milling machine will be my next purchase later this month as the Griz' is havin' a sale & I got a coupon!
