SCORE!
SCORE!
SCORE!
charlie belden
Friend Joe, the tree trimmer, tells me he's got a bunch of redwood slabs that he cut years ago sitting under one of his oak trees - and wonders if I want any of them - cause otherwise he's taking them to the dump.
So I drive up to his place up the road, trod through ten years worth of fallen oak leaves to look at - a half dozen slabs of redwood - four to almost six feet long, two and a half to almost four feet wide - AND - 4 to over 6" thick - cut just above ground - AND below ground.
Even under years of weathering, I could see his was NICE STUFF - and almost dry. DING! DING! DING!
Tell me which ones you want and I'll drop them off at your house later today
(Not only free wood, and very NICE wood - but it's delivered to my house! Pinch me - I must be dreaming)
Five of the six slabs.
Almost six feet long
Detail of the almost 6 foot long slab. Interesting yes?
And this puppy is 6+ inches thick
This hints at what's inside of one of the slabs
And here's what I found under the dark gray weathered surface after some hosing and brushing a slab off.
The thick slabs will probably be for tall narrow hollow forms. The rest will probably finally get me turning some bowls.
Now bear in mind that here in the San Francisco Bay Area, redwood fences and decks are the norm. It's so common we take it for granted - and hardly notice it. I've used old weathered fence boards for tops of bonsai display table - finding amazing feather grain and occassionally tiger maple like figure. But if what I think is in these slabs . . .
YouTube vid of my Happy Dance may follow ; )
Re: SCORE!
Re: SCORE!
George Van Beynen
What a find, beautiful grain!
I see some nice sculptures in the pile also. ;-)
Re: SCORE!
Re: SCORE!
dick gerard
Charlie,
This is just proof of good karma ... what goes around comes around ... and it sometimes comes around in spades! Good for you ... looks like some mighty fine and interesting wood there. Wish I lived closer ... I'd be over to your place begging for scraps! Be sure to post some pics of the finished product from this score.
Dick
Re: SCORE!
Steven Antonucci
You call that a score?
steven antonucci
Redwood is too soft to turn. I can't believe your friend made you haul away his garbage for free...
LOL
I have a bunch of redwood burl sitting in my pile. I may just have to go get a piece now and turn it. I had to load it myself, so it wasn't as good as your score, but it was also free. If I were you, I'd seriously consider learning how to make wide, flat vessels to exploit the flame in the one piece. It would be awesome.
Mega Score.
S
Re: SCORE!
Re: SCORE! *LINK*
charlie belden
I see there are some folks here from The Wreck (usenet newsgroup rec.woodworking) ; )
I'm more than a bit intimidated by this stuff. Just deciding where to cut it makes me apprehensive. Stuff like this doesn't come around often. It's not like it grows on trees or anything ; )
I used to do jewelery and lapidary. If you every worked with fire agate with its bubbles of fire in its brown matrix, you know that the fire my be only paper thin and easily ground away in an instant. This stuff may be the same way.
In Flat Work, it's easier to Read The Wood since you can see the faces, edges and ends of boards. With these slabs there's years of weathering and chainsaw marks hiding things. Because they're partially root burl there are hollows and holes and probably voids I can't see. I think this stuff warrants some hand planing and sanding to expose more of what might be there. Then maybe the wood will give me suggestions about how it wants to be cut.
(You're probably thinking "Oh lord, another hippy dippy, touchy feely wood whisperer who talks with wood. Yeah right. Well check out the attached link - and maybe, just maybe - YOU'll strike up a conversation with some or YOUR wood . . . )
OK - so maybe you don't buy that wood can talk. But it CAN sort of WRITE - some of its life history - in its growth rings. And if you understand wood's "written" vocabulary, you CAN "read" some of the wood's story.
(You're saying to your self "Wood talks AND writes? What's this guy been smokin'? Read wood? Oh sure.")
Maybe it's the alcohol fumes of the shellac I applied to this piece. But I'm beginning to read some of this chunk of woods story.
"I grew at the bottom of a fair sized redwood. Not Giant Sequoia - but a decent sized redwood. And I grew up under a lot of pressure - both because of all the weight trying to squash me into the ground - but also from struggling to keep the tree from falling over. That's a LOT of forces I had to resist. So, lacking strong bones, I developed muscles, tendons and ligaments to do my job. In body building terms, I'm "ripped", with great "definition". Not Arnold Schwartzennager - more Lance Armstrong - nothing there just for show - just everything needed to do my job."
Have a look and see what YOU read.
I'm starting to think this may turn into a Vicky Jordanesque thing because I'm certain there are folks who have the technical skills and aesthetic eye to really do this wood justice.
Think I'll call a guy in our turning club who can really read wood and get some cutting advice from him. And since he's one of those people who can read wood, turn it excpetionally well AND create really nice pieces . . .
Conversations With Wood
Re: SCORE!
Re: SCORE!
George Guadiane
Charlie, the curl in that block goes all the way through. It may not show in the end grain, but if you look at the wrinkles in the bark, you can see that the curl is there too. If that piece were mine, I'd make it into a hollow form with a void (bark up).
Re: SCORE!
Re: SCORE!
Starry S Chan
Where do you reside in the bay area?
Which wood turning club are you in?
Starry, Saratoga, CA, sschanATsbcglobalDOTnet
Re: SCORE!
Steven Antonucci
Refer back to my opinions on stewardship
steven antonucci
When I teach, I often try to educate people on the stewardship of materials. This tree may have taken 2000 years to get where it was going. As a turner, you owe it to the tree to treat it with the utmost of respect.
I have an almost American Indian-like philosophy about this kind of material. I save every usable piece with as little waste as I can produce. I may not turn some of the smaller blocks, but I know people that make bottle stoppers and pens so I put it aside for them. You should consider yourself as a steward of the material.
I have a bunch of similar material awaiting it's final destination. I am in no hurry to turn it, nor should you be with your material. If you don't know what to do with it, stack it until you know exactly what to do with it. Remember that you only can cut it one time, and be deliberate in that action.
Finally, in your conversation with the wood, make sure that you come to an agreement on what it wants to be/what you make. Too often, people work within the confines of what they see before them and do not listen to what may be obvious if they just stopped for a minute. Just because there are big slabs does not obligate you to make big things. There is a fine balance between conservation and compromise.
Good luck, and be sure to post some of the work you produce. You'll do fine.
Steven
Re: SCORE!
Steve Kubien
Re: SCORE!
Steve Kubien
Geez Charlie, that is some fabulous stuff. Have fun with it. I only ask one thing... Please, please, please don't gloss the h@ll out of it with wipe on poly or gloss tung oil.
Re: SCORE!
Re: Refer back to my opinions on stewardship
George Guadiane
Steve,
I came up learning about Oriental stone carvers and how they sometimes study a valuable piece of "rock" (jade) for years, decades even waiting till the form reveals itself and their skills have come in line with the vision. They then form a partnership.
My own philosophy on wood use and/or how I go about finding the form that is trying to get out is much like that.
I agree with your post and share your desire to make the best use of the most material. My philosophy is a combination of not being wasteful, finding the form in the material, being patient till it speaks and then using my best skills to let it out.
AND to let the wood be what it is rather than what I want it to be.
In this case, on this piece of wood, I saw, in the pictures, a low HF with maybe a bark edged opening and a void near the super curly "corner." It may be that I'm not listening, but I'm thinking that if it were in MY hands it would be telling me to make that form.
Some pieces of wood sit for years waiting to call me to make them, some never do and I eventually get them into the hands of others (my club members love to see me coming - OK, maybe it's just the wood thy like to see).
Re: SCORE!
Re: SCORE! *LINK*
charlie belden
Cambrian area, just off 85 & Union Ave.
Silicon Valley Woodturners
I'm in the book - 559 prefix. If you'd like to see this wood give me a call. Not ready to start distributing pieces yet - but you're welcome to peruse and make suggestions as to how to cut it.
Re: SCORE!
For Instance:
George Guadiane
In looking at the latest pictures I thought this would be my approach:
I think I have them both oriented top and bottom matching. What I saw was where the concentration was strongest and where the shape of the block would allow a form to be made.
The highlighted parts show (more or less) where I would cut the round.
Bark side up there would almost certainly be a void in the upper right hand corner.
Re: SCORE!
Steven Antonucci
Oh... I got one too!
steven antonucci
So many ways, so little material...
I would potentially cut that block in such a way that I didn't get the natural edge and the void. The figure running uninterrupted across the surface of the wood would be spectacular.
Perhaps a smaller something out of the piece I cut off... at least bottlestoppers for my friends.
And hence you know why I also have a huge pile of redwood burl sitting in my rack. Only one piece told me what it had to be. The others are still figuring themselves out. :)
Steve
P.S. I'm merely pointing out the internal dialogue I have had with a piece that is at least as good as this one, maybe even better...
Re: SCORE!
charlie belden
I'm in total agreement regarding stewardship and patience.
But there's a fine line between stewardship - and hoarding - made worse by friends who make their living taking down parts or all of trees - semi-regularly - trees with NICE wood. So when the inside woodrack is full, everything that has room under it to stash wood is filled, the racks behind the shop are stacked with nice boards, the driveway is lined with logettes and half logettes and slabs . . .
I did finally find two guitar makers who would use three of the nine boards of Bear Claw Spruce I was entrusted with 10 years ago, by a guy who had been their guardians for 30 years, who was entrusted with them by someone who had had them for nearly 20 years.
Re: SCORE!
Bill Blasic
Bill Blasic
Charlie,
I think no matter what you decide to make out of it your going to have a big smile on your face.
Bill
Re: SCORE!
Don Leydens
Re: SCORE!
Don Leydens
Doesn't get any better than that!!
Re: SCORE!
Definitely deserves a Happy Dance !
Don Orr
Awesome haul.
Re: SCORE!
Re: SCORE!
charlie belden
Actually, it can get better than that - if the Pay It Foreward idea happens. Folks get a piece of this stuff, I get some pictures of what they do with it, and each recipient makes a contribution to an organization that does good for others.
