I think I found a solution.....
Randy Gleckler
I wanted to thank the people that responded to my problem of turning larger than my lathe. That combined with a conversation with my wife about the issue got me thinking and I came up with a Good solution I think.... at least it worked very very well for me.
This is a pic of the original Idea... I'll let anyone know thinking of this, it was a BAD idea in my execution of it at least. I found this design VERY wobbly.
Basically 1/2" galvanized that led up to 1" which I drilled and threaded a clamp on to hold my existing tool rest
Basing the thought process on what Powermatic sells as an Outboard extension, and the versatility of some of the other suggested designs. I'm not sure this is the final design as I'd like to add some more weight to it, and make the "Bed" out of steel when my welder buddy get's back in town, but it worked well for what I needed it for. Basically a Saw horse 18" setup to take the Tool rest from the lathe, and then a Galvanized pipe extension, again threaded for a bolt to hold the tool rest. Best of all, I can move it as close, or far away as I need. Let me know if you have suggestions or questions.
