Question on vernier scales
I have to make a multi sided walnut vase that matches the bottom of a stool. For lack of a better description lets call it 16 sided with a flute that fills each segment from top to bottom. Here's my problem. I have an index wheel and I think it might be hard to get the index to line up properly with the center of each segment.
Several times I've thought it might be nice to put a short pin on the backside of my chuck that would fit in a hole in the index wheel so when you install it, the index wheel would be in the exact position each time. You could take the chuck off the lathe for other carving details and then put it back on and index it exactly the same.
Now, I would like to drill several holes in the back that work like a vernier scale. In other words if one hole didn't line up exactly I could just try another one. Does anyone know how you would calculate this? I think you could mark off say 16 distances we'll call X. Divide one of those distances by 10 which I'll call Y . then you would drill a hole, rotate the chuck x+Y and drill another. The next hole would X+Y+Y, then X+Y+Y+Y, etc. do yo think that would work?
