Two new tools (for me)
Steven Antonucci
steven antonucci
A buddy of mine invited me over today to spend the day in his shop screwing around... I grabbed a few things having no particular feel for what he was expecting. I know that he has a plan, but at this point, I am not in on it... so I ride the wave.
After showing him a few of the things I am working on, he says "I want to make a hollowform". He also says that he's got a couple of new tools (which means he's going to lean on me to show him how they work...). The first tool is the swan neck tool from EWT. It's the one with the flat bar and that small C shaped section on it. And a carbide cutter (gasp!)
So we get something that looks half decent on the lathe and decide it's time to start hollowing. After some fiddling around, I figure out how to used it. If I was to review it, I would say that it works, and even better than I expected, but I still wouldn't want to hollow with it exclusively. If I owned one, I would save it for finishing cuts, as I think it left a pretty nice surface.
As we got deeped, it became obvious that we needed something longer and stronget, so my buddy shows me the second tool... a Hunter # whatever. It was about 5/8" or 3/4" bar with a ~5/16" cutter. He handed it to me with a goofy look like "I can't wait to see what happens next", but he didn't know that John Lucas had fully instructed me with how the Hunter's like to be presented! I felt for the bottom , rotated it to the sweet spot, and filled the vessel in two pulls. After 20 seconds of blowing out chips, he tried it and got the jerkiness that some folks get. I helped him get on bevel, and he was cutting.
So is this a reversal of fortune? Will Steve be trading all of his lowly steel tools for carbides?
Nah.
But it was fun while it lasted. Two products that work well in certain types of work, but have a learning curve. Life is a series of trade-offs...
Steve
P.S. Outside of the vessel was cut with a Thompson 15V...honed once ;)
P.P.S. Yeah, that's right, I sharpened once today in 7 hours of turning...
Re: Two new tools (for me)
Bill Blasic
Bill Blasic
Steve that 15V is sweet isn't it! What type of wheel did you use? I had no problem with the standard wheel from the Woodcraft grinder.
Bill
Steven Antonucci
Experimenting
steven antonucci
I have a Tormek. My buddy has a white wheel on his grinder. I also tried using a diamond hone and a belt sander with 400 grit paper.
Here is what I have settled on:
The Tormek leaves a very fine burr if the stone has been graded to what they call 1000. It's not a real 1000, since my hone is 1200 and I can see a noticable difference in the finish. The Tormek has no issues cutting the steel. I use the green DMT to hone the heel and the bevel in between sharpening. When done right, this gives me the best edge I have been able to achieve. (no different than my other tools)
I am still playing with the grind on the 15V, as Doug's flute is a little bit different than the Oneway. We were stalling the lathe at my buddies shop, which has a DVR in it. When you stall that lathe, the voltage drops and the electronics just shut off. He needs to put it on a dedicated circuit. When he does, I plan on testing the limits of the gouge (1" cuts...)
S
Alan Zenreich
Re: Experimenting
Alan Zenreich
Steve,
I don't know which DVR your friend has, but mine (an XP) is configurable as to how much of a catch will cause it to stop.
It's been a while since my last significan catch on my lathe, but if I recall correctly, a catch simply stops the lathe, but does not shut down the electronics at all... you just press the start button to bring it up to speed again.
So there might be something odd with his configuration, or my setup might be a later revision.
Configuration settings
Alan how are the settings for a catch labeled? oops, Oh darn, Why is this happening, Holy *&^#, and finally, Gotta change your pants.
Alan Zenreich
Re: Configuration settings
Alan Zenreich
John,
You're close. I like your descriptions
I believe it's the speed stabilization function.
The three preset configs are (from the user guide)
Soft: for light work at speeds slower than 500 rpm
Normal: Suitable for most work and is the default setting
Hard: For heavy ad/or out of balance work a speeds lower than 500 rpm
Looking around the net some folk had their boards replaced if a catch caused a shutdown instead of just stopping the lathe and then restarting.
