How would you....
How would you....
How would you....
Randy Gleckler
I was messing with turning a platter. Got the idea stuck in my head, finished the first part, then realized to do the 2nd, i'd need more turning capacity than my Powermatic has. So I need to Outboard turn, however, I don't have an outboard stand/setup. I tried something but it was very wobbly and don't think safe. So I was looking for ideas... biggest problem is I don't know how to weld and my only friend with a welder is out of town for a few weeks. So, how would you tackle this dilemma?
Re: How would you....
Make a smaller platter??
:D .
Okay - reality check. A platter is used to hold things unless it just a decorative platter. If it holds things, it has to be put away - correct?
A typical kitchen wall cabinet has a rough depth of 11-11 1/2". The standing cabinets have a depth of about 23" or so.
A Powermatic 3520 will turn a platter that is roughly 20" in diameter - which, in my opinion is plenty big enough for a platter.
But to get back to you original question. Make a stand out of 4 x 4s or 2 x 4s. Have two uprights about 10" apart. Take a piece of heavy duty pipe - drill holes in the uprights at the same height and put the pipe through the holes.
Jorge Casta�eda.
Randy,
You could make a stand with galvanized pipe , 90 degrees elbows and flanges.
One made by S. Antonuchi was reposted by somebody else yesterday.
Re: Make a smaller platter??
Randy Gleckler
Yes, but doing Offset on those dimensions, can cause problems. :-D Took me a minute to figure out your explanation.. but that might work.
Randy Gleckler
I've been thinking about that, but the Tool rest would have to mount to the Way's behind the headstock, then come out in front, not sure that'd work or be any more stable than what I already tried.... but I have thought about that pic for a few days now... I'll likely post both pics once I get figured out, just brainstorming here.
Re: How would you....  *LINK*
Randy I've tried several things over the years. The first thing was to move my floor standing drill press over to the lathe. Clamped a pipe to the table and used it as my tool rest. It was OK as long as you took light cuts. I would definitely clamp it better next time.
Then I built a free standing rest out of a truck wheel. It doesn't work very good but it got that project done. I should fill it will concrete to add some weight. Your welcome to come and borrow it if you want. I'll even do the concrete filling for you.
The method I recommend is to make a floor standing pipe that attaches to the lathe similar to the vicmarc. Check out the link on the bottom right. I believe it could be jury rigged out of square tubing and bolting parts together with maybe a few heavy duty wood parts.
http://www.vicmarc.com/default.asp?contentID=545
Richard Allen
Richard Allen
Hi Randy,
I would take a different approach.
Find someone with a bigger lathe and turn the platter on that lathe. Someone in your area must have a larger lathe. Contact your club officers to see if they can put you in touch with someone that can help.
You will find that this huge platter is the last one you are going to make or you will find that you really like making big platters. Either way finding that out on a bigger lathe is a safe and effective way to get this platter done.
Powermatic has a solution for you. Attaching a bed extension lower on the outboard side of the lathe... This will give you a stable solution for the next time you want to turn something big.
Jorge Castaneda
Randy,
The easiest and best solution I found was to buy the extension table, makes you PM 3520b so much versatile and with that you can turn up to 39".
Or else if you are getting into big bowl turnings, maybe think VB.
That's what I'm going to do. I have a 3520A. It does not have the mounting holes on the legs. I have a bed extension. I'm going to drill holes in the legs and put a heavy metal plate on the inside of the legs. I will drill and tap this to hold the bolts for the bed extension.
Jorge Castaneda
That will work.
