I bought a used Gast 0523 vacuum pump on CL. This pump can only run for about 45 minutes as it will shut itself off because it is getting too hot. Is this normal for Gast vacuum pump or is there some wrong with this pump? Is there a way to keep it running cooler?
Have you checked your muffler (if you have one) - if they are partially blocked, they can cause overheating.
Have you checked your filter (if you have one) - if they are partially blocked, they can cause overheating.
Relief valve - if partially blocked - can cause overheating.
Plugged lines - can cause overheating.
Dust or powder in pump - can cause overheating.
They are not that difficult to service. Of the vacuum pumps, the Gast's are relatively easy to service. The bigger guys that are on a mass spectrometer or an electron microscope - those are another matter.
If none of the suggested items to check are the problem there is a lubricated and an oiless version of the same Gast 0523. 45 mintues on the lubricated unit without using lub would most likely be hot one! I've never seen data on them to say if they are continuous duty rated or not.
I took the pump apart and the inside is quite clean. I can't find the relief valve. I use compressed air to clean the filters and the muffler. I also clean the inside of the pump with a dry paper towel. It is not really that dirty. The vanes have about 50% to 55% left. I will change them when I no longer get enough vacuum. I will order a service kit soon.
For oil-less pump, the pump will get really hot. The strange things is that the motor is not air-cooled. Gast made special version for each customer. It is possible that this customer did not want a fan in the motor.
I put the pump back and I am running a test again. I hope it can run for a few hours.
After the cleaning task, the pump ran for an hour and it is still running. This is a limitation I can live with as I should be able to finish the bottom of a bowl within an hour. I may build a reservoir so that I do not have a sudden loss of vacuum.
The pump runs very hot. It slowly went from 65 degree C to almost 80 degree C in about half of an hour. GAST is a well-known name in vacuum pump but I start questioning the sanity of the rotary vane pump design. The friction of the pump surface again the end plate generates a lot of heat. I can feel the hot air coming out of the muffler. I cannot see how this can be rated for continuous duty as the heat just keeps on building up at the pump until the motor thermal sensor trips.
A Google search shows that hot Gast pumps are experienced by some users and not by others. This may well be related to model and intended use - apparently the model designed for use in the printing industry is made to run for long periods of time.
A solution appears to be to direct a small fan onto the pump and I've heard of this being done when refrigeration compressors are used of vacuum clamping.
One use for the Gast 0523 is as an air pump for septic systems. That has a 24/7 run requirement. Our system has an older RV03 that started sounding a bit off. You do not want to be with out an air pump with an aerobic septic system. I used Gast cleaning spray AH255D and it helped a bunch. I also purchased a repair kit to have on hand just in case.
A side note: The septic inspection company installed ($500) pump when the original Medo diaphragm pump went out about 8 years ago. In researching my current issue I found out all it would have taken was a $30 repair kit and five minutes time to fix the Medo. I still had the pump but the kits haven't been available for a good 5 years. Ignorance can be very expensive.
I have an older one and it gets quite hot. It has never shut down on me so far but then I'm not sure I've ever run it for more than 15 or 20 minutes at a time. I've wondered if it had a thermal shut down. What I'm planning on doing it building a cabinet to go under the end of my lathe that will house the compressor as well as have a drawer for tool rests and such. I'm planning on putting a fan in the cabinet to keep the motor cooler than it is now just sitting in space.
It is a thermal shutdown. There is a label on the pump stating that.
I am also planning to install a small a fan on top of pump to provide better air circulation. This is more for the longevity of pump as 45 to 60 minutes interval is adequate for vacuum chucking.
BTW, the temperature on the outlet is so hot that it dried out the o-ring on the outlet side. The gasket between the muffler and the end plate is also hardened because of the heat. These will be replaced when I eventually replace the vanes.
Starry, don't know but mine sits on top of a fan. It came that way. Maybe yours was supposed to have one but the previous owner modified it. Check with William Noble he is very familiar with the Gast pumps. wnoble.com I think.
