Modern Longworth Chuck
Emmett Manley, Lakeland, TN
Has anyone had any experience with the Modern Longworth Chuck now being offered and promoted by Craft?
Other than the price, what are the major concerns about this product? The projected ease of use in finishing bowl bottoms sure is tempting.
Re: Modern Longworth Chuck
Chuck Bjorgen
I received the email promoting that new Longworth and have to admit it looks tempting despite the price. Converting to the Jumbo Jaws on my Talon is a regular pain. I may wind up getting it next time our club has a group purchase from CS.
bob davis
i made the one from plans in MoreWoodturning several years ago...works fine.
Mark Trenier
I just got mine and I have used it once. Keep the lathe speed slow--the chuck says never go faster than 600 rpms--and it works pretty slick. Much easier for me than a jam chuck and it's priced about the same as jumbo jaws and I don't have to mess with putting the jaws on and off. Fit just fine in my chuck. Seems well made I'll have to wait and see if it's worth it in the long haul.
Hope this helps.
Mark
Re: Modern Longworth Chuck *LINK*
Fred Holder
I've had a copy for about eight months now, actually two of them, one for my Nova DVR and one for Mildred's OneWay 1018. They work very well and as with all of this type of chuck it is best to use tail stock support as long as possible and to keep the speed down. I believe the instructions said keep below 600 rpm, but I felt more comfortable with it at 400 rpm.
I did a review of the chuck for the January 2011 issue of More Woodturning magazine, which is available on the Internet at the link below. The part that I like best about it is no need to have an insert to fit your lathe, your chuck with 2 inch jaws is all the insert you need.
Fred Holder
Link to January 2011 More Woodturning
Thanks to everyone for their information and insights. I'll wait for the next discount or free shipping offer from Craft and order one of these chucks.
john lopez
I've had mine for a few months and used it 4 or 5 times.
One advantage over a doughnut, Straka or other subspecies of Longworth in favor of this one is that it self-centers easily.
Many of you may not have problems with that but I do.
I'm on the ham fisted side of things and many of
my biggest accidents and failures have been during the reverse / finishing process.
Another thing with the Straka design that I made is, as my bowls got deeper I had to go out and get longer screws.
Phenolic seems very strong for the application .
Glide with little drag may be why this material was used.
Once you pull the plates in the right direction it operates smoothly.
The forces applied during the finish turning and sanding modes are
not that great. Light cuts are recommended and the 16 incher has a sticker saying max speed : 600 rpm
It is a lot of money but for me it has been a good option.
If I had the tools, material and skill to make my own it would make a worthy project.
I was working on a series of hollow forms turned from exceptional wood and a gift came my way .
A criticism or two about the Longworth would be that the 8 bolts and wingnuts just don't seem heavy enough.
The manual stresses that they only need to be finger tight
or the vessel may crack.
An Allen wrench is provided to keep the bolts from turning during the mounting process.
I don't like the galvanized wingnuts on the headstock side of the plates and will probably replace them with some bigger plastic coated
toggles.
Doing that may effect min. diameter in the contraction mode.
But given the information again that this chuck is not intended for heavy stock removal and more specifically meant for finishing bottoms
it may be one of the better designs.
cliff smith
got one after seeing it at the woodworking show in charlotte nc. works well hated changing chuck jaws , centers easy, well made.
Make your own!
Jorge Casta�eda.
In a couple hours with stuff most of us have around you can make a very good one.
In about two hours time I made mine using a 24" x 24" MDF and a matching piece of plywood. With dividers, scribe the biggest circle, I left 1' at the edge, then scribe the smallest circle, determined by the glue block attached to a dedicated faceplate, and then using the same radius of the big circle, divide it in six.
A baby router mounted on a strip of plywood was used to cut the slots through both boards simultaneously staring within the big circle and stopping tangent to the small. Once all the slots are cut, flip one beard and insert the bolts and whatever you re using for the buttons, I did use wine corks.
With a jig saw cut excess material and once the epoxy has set, true the rig on the lathe. You are done! now you can finish the bottoms of those bib pieces...
The total investment was around $30.00, the bulk of that is the dedicated faceplate, and some bolts nuts and washers..
Have fun!
Re: Make your own!
Jorge, I am sure that making a Longworth chuck would be a simple matter for many people, but I am not among that population of skilled woodworkers. Of the items you listed, I have the wine corks. I don't have the jig saw and certainly no router (I have never even seen a router much less used one). Why, I don�t even possess a table saw which I understand many woodturners use for storing their wood.
So, I fear that my effort to manufacture a Longworth chuck would be a time consuming, stressful, and expensive undertaking, with all that effort resulting in an unsatisfactory product.
Therefore, my rationalization for the purchase will be that I can invest a few hours in making bowls which I will sell to obtain the money required for the slick factory-manufactured chuck. Everyone wins, including the folks selling the chucks. Rationalization is a wonderful process.
Thanks for the instructions and photographs and perhaps others will be motivated to make their own bowl finishing chuck.
Re: Make your own! *LINK*
Fred Holder
For people who want to make their own Longworth Chuck, I've collected quite a bit of information on it, including the first article published by Woodturning Magazine on the Longworth Chuck. Personally, I prefer to be turning wood and let someone else make the chucks. See the link below for enough information to make your own.
Link to Longworth Chuck Material
Steven Antonucci
Hey!  That's my line!
steven antonucci
