General 160 lathe
General 160 lathe
General 160 lathe
Joanne -near Dansville, NY
There is a General 160 lathe for sale in the area with a duplicator.
I was wondering what the pro & cons were- I have heard they are a good lathe-
1 HP motor 110, purchased new in 95, in perfect condition has seen very little use, they are asking $1500 I want to start turning again, I haven't done any turning in 25 plus years.
Thanks in advance
Joanne
Re: General 160 lathe
If it is the variable speed, I would consider it.
I've turned on the 160 and the 26020. They are well made. I don't know about the $1500 part though. You can get a brand new Jet 1642 for not much more ($1785 with free shipping).
Bill Howatt
Mechanically, they are very good lathes but as JL alluded to how good the deal is depends on whether or not it is a variable speed model and I'll add, how important is having the duplicator to you. Unless you are going to do spindle production work it most likely has a value approaching zero.
If it is a variable speed it almost certainly is a mechanical variable speed (Reeves drive that changes pulley diameters) and not electronic variable speed. The General Reeves drive systems are usually very good and shouldn't be confused with the same idea implemented on cheap lathes. However, this is one thing I would check out and make sure it is working properly.
The 4 speed lathe has no control on the front for setting the speeds and is done solely by changing the belt to 1 of 4 speeds. This model has a lowest speed of about 850 RPM which is too fast for bowl turning unless the blank has been carefully prepared so it is not too badly unbalanced. This lathe is best used for spindle turning. IIRC, the mechanical variable speed model will go down to about 500 RPM which is a lot better but still a bit on the fast side.
My guess is that it has a 12" swing although General did bring out an 18" model. Some people, especially these days, will consider that a bit on the small size although a 12" bowl is probably a lot more useful than some giant size.
I have a 20" General with electronic variable-speed and I would never buy another lathe, unless I was just turning pens and the like, without electronic variable speed. No, you don't really need it but it allows you to go down to very slow for large out-of-balance blanks and adjust the speed upward until vibration starts.
Overall, if it is the 4 speed only model and you want to do bowls look elsewhere. I would consider the price high for this model as well. If the seller says that the new price is over $3000 take it with a grain of salt. General list prices, IMO, tend to be too high these days.
Bill
The variable speed General 160 was my first ......
JamieDonaldson
...."good lathe" many yrs. ago, and I still have it because its the only long bed in the shop. The Reeves drive has worked well enough for limited use, and link belts make belt replacement much easier as well. I don't know about that price, but some dickering might bring it down to reality.
Ruth Niles
Joanne, I turned on the General 160 for about 8 years. I now have the 260-20 and, like the previous posters, would never buy another lathe.
I also agree the price is high and the duplicater is useless, even for spindle turning (and I did many years of spindle reproduction turning!). Maybe do a search on craigslist and google and even on the General website for value.
If it is the Reeves drive, which I'm betting it is, that really is not a negative. If the lowest you can go is 500 rpm, you can put 4 50-lb bags of sand on the shelve for great stability.
price too high
bob davis
ibought my general 160 variable speed in 1995 for $1600.. very good lathe. sold it recently for $500. buy the jet as electronic variable speed is much better
Re: General 160 lathe.Motor pulley
bob davis
i recuced the low speed to 360 with a smaller motor pulley
Steve Kubien
I wouldn't touch it
Steve Kubien
Sorry, but I wouldn't go near it at that price. As others have said, the Jet 1642 is close in price and the Nova 1624 is only about $1100. If I was closer I would try to sell you my Nova because I have a DVR XP arriving on July 16th.
Re: I wouldn't touch it
woodspinner-Harry Robinette
I bought my 160 12" lathe in Feb.2000 for $1250. and change.Low speed 300rpm reeves drive.In 2002 I got a set of castings from General to make it a 18" lathe and also put a DC drive on it with the reeves.This way I can keep the torque up and the rpm low.I now have full vair speed 0-4800 rpm. My point $1500 is way to much for that lathe. By the way I use my General almost daily and if you keep the reeves greased it will last a very long time.Going on 11 years daily use and runs like it did new.
I got an email back today from the guy that was selling the lathe and he said he sold the lathe for $1500. A friend of mine that does a lot of turning and has a General 260 thought it was very high and everyone that responed to my post thought it was high too........
Jet was having a 4th of July sale through the 8th, so I ordered the 1642 evs 1 1/2 hp for 1784.99.
I should have it in 10-14 days!
Thank you to everyone for your input.
Joanne
