First Cut At Laser Engraver Carving Primer *LINK*
charlie belden
A laser engraver opens up lots of possibilities for surface treatments on/in turnings.
BUT - as usual with any new tool - there's a moderately steep Learning Curve. You need to know
how to set up the piece and the laser, have a basic understanding of the laser's modes of burning
things, be able to get your artwork into something that works with the laser engraver, understand
what the laser's Printer Driver's PAGE SET UP options do and how to use them, come up with a
way to hold your turning for lasering, . . .
I've put together a web article on most of that which - I hope - will help flatten that learning curve
a bit.
I'm too close to the subject to be able to spot wholes in the info and the illustrations probably
will need some more work to make them clearer. As is always the case with instructions - too much
info can be overwhelming. But too little information can lead to frustration due to critical gaps.
This is a first cut at the subject so questions, comments and suggestions would be greatly appreciated.
Laser Engraving Primer Table of Content
