Fire extinguishers
Fire extinguishers
Steve Kubien
Fire extinguishers
Steve Kubien
No, I have NOT had a fire. Not even a close call. That said..
I finally got an extinguisher for my shop. It's a 5 pound ABC unit for my 10' x 20' shop. The shop has one exit point (overhead garage door). My lathe is deep in the shop, the grinder and bandsaw are halfway in. Where do I hang the extinguisher? My guess is near the grinder but I'm not sure.
Your opinions and info are welcome.
Re: Fire extinguishers
Carol Reed, Strawberry, AZ
Next to the door! I was advised this by fire personnel many years ago. This way you get to make the decision for flight or fight in the best place, at the door!
Dale Jablonski
Dale Jablonski
I agree with Carol, hang it near the door so that you or someone who might be coming to your aid could use it. Also, if it's available, the best fire extinguisher is something called "Cold Fire". I've used the foam when I fought fire and it does a fantastic job.
Door, concur.......
Richard Jones
Bill Turpin WNC mountains
OSHA says that garage doors are not legal exits! If the door sticks or power for the opener is off, YOU ARE STUCK. Get another FE, minimum 5#. A real fire, like grease, finish, or parts washer, needs 10# to be put out. Another $40 now could save thousands later. Ask the local fire dept where to put the fire extinguisher. They will give free advice. Always aim the stream at the base of the fire.
bill Crommett
Many years ago I had an engine fire in my automobile, which I fortunately put out with a small Carbon tetra chloride extinguisher (now illegal). When I had a boat (cruiser) I had Halogen extinguishers for the engine room (now illegal). So you can assume that I am ever watchful for fires of whatever origin. About ten years ago we had a fire in the barbeque due to rusted out burners. We used the ABC extinguisher to great success, but the mess of cleaning up after the fire lead me to the decision that the mess wasn't worth the cost difference between an ABC and a C02. So now I have two CO2 extinguishers, with one near the kitchen and one at the shop door. So far I haven't missed the extra $100 difference.
Rob Wallace
AT THE PRIMARY EXIT DOOR
Rob Wallace
Steve:
At the University here (Iowa State), every one of our labs, regardless if a chemical use lab or not, MUST have a fire extinguisher affixed to the wall within a set distance from the primary exit door of the room (I think it has to be within 6 feet??). As lab directors, we are given mandatory training in lab safety operations, and fire extinguisher location and use are part of this training.
If there is a particularly hazardous operation being performed (as in some chemistry labs), a secondary extinguisher can/should be located close to the hazard area, but it does not "cover" or "replace" the room from being protected by an extinguisher at the door which is an absolute requirement. All extinguishers must also be properly and appropriately rated for use on fires probable in the area.
There are several reasons why the door location is mandated (not the least of which is for people coming from outside the room to the aid in extinguishing the fire, particularly if the occupant(s) is/are incapacitated), so I think most fire professionals would advise you to have the primary (or single) extinguisher located at the main exit door of the room. (BTW - We can be fined if our lab's extinguisher has been moved, relocated, or obstructed with "stuff" placed in front of it.)
My shop has a 10 pound extinguisher at the door main door, and another secondary 5 pound extinguisher located at the dust collector area.
Hope this helps,
Rob
Steve Kubien
By the door it is!
Steve Kubien
This all makes good sense to me. It will get mounted by the door tonight. Thanks everyone.
Re: By the door it is!
Bart Leetch
Don't buy a fire extinguisher with a plastic valve they tend to shrink with age & allow the pressure to leak down. This is advice I received from the fire dept.
Joe Herrmann
I have three doors in the shop and I have an extinguisher hanging on the wall beside each door.
Jesper, Denmark
Jesper, Denmark
Location near the door is definitely the right one. There are also recommendations/specifications for the height of the location, so that people coming to your aid would find it where they expect it to be.
Not having a safe exit door - other than the garage door - is also somthing you should consider fixing. Fire extinguishers and planned exits are like fire insurance: You hope that you have wasted your money and never need to collect.
Steve Kubien
Steve Kubien
I get what you and Bill are saying about another method of egress. Truly, I do. One problem...I live in a townhouse.
