whatcha fill your holes with?
avalon
The other day i ground up a piece of old copper pipe and used the fillings to fill a gap...
seen that they sell powdered turqoise, coffee grounds, sawdust, etc...
what do u guys like to use? i'm looking at other things to use...
Re: whatcha fill your holes with?
Terry Scott
Brass tailings from a key cutter machine inlaid with epoxy
I get a magnet first and take out any steel
But the Aluminum and brass go well together
Steven Antonucci
I am a big fan of air
steven antonucci
Instead of filling them up, I tend to blow them out. The more holes, the better it looks.
S
Re: I am a big fan of air
Bob Lalonde
Me too. I like the "natural look; more green.
Barb Siddiqui
Barb Siddiqui
What a great idea! Thanks, Terry, I'm going to visit my local key shop today. By golly, you never know what you'll learn around here!
Re: brass
Jack Savona
Before I use my key filings, I run them through a coffee grinder that I picked up at a yard sale for a buck. Makes the brass more of a uniform powder and gives me a smoother surface.
Hint: cover the magnet with paper or plastic when removing the steel particles. Saves trying to clean the magnet. DAMHIKT.
Barb Siddiqui
Re: brass
Barb Siddiqui
Oops.. thanks for mentioning that, Jack; I didn't think of shielding the magnet. Ouch! Good point.
Bill Turpin WNC mountains
We turn a lot of ambrosia maple. Without holes, no ambrosia. We accent the holes, with air and magic markers, unless it effects functionality. "Soup bowls" get filled with sanding dust and CA. Pieces for fruit, wrapped candy, popcorn, etc have holes...that is green. I sure hate the word "Green". Is leaving poison ivy alone green? I much prefer goats, they love the stuff.
Yum, Yum!
avalon
what about cracks made while shrinking?
Chip in Plano
Let's see....
Air (aka nuthin') is easier and simpler. Filling seems to just prolong completion of a piece but when I need/want to...in not particular order....
Coffee grounds/beans,tinted inlace, turquoise w/inlace, tinted epoxy, copper shavings, brass key shavings, aluminum shavings, sawdust from piece, tinted saw dust, tinted dry rice, tinted dry grits, various colors of Rub'n'Buff. Most of these are used in combination.
The one that really comes to mind is turquoise chips held with thin CA then I filled in the voids with gold Rub'n'Buff paste wax. I had to do fill the voids several times as I turned down the turquoise chips exposed more voids. Black inlace or CA looks good, too.
Jason Silva
I like to use 5 minute epoxy with a few drops of black india ink. Im on my way in no time after aplication.
Be careful....
The filings right off the key machine are like tiny splinters on steroids. If you would like to have fifty slivers in a finger tip, go ahead, rub some filings into a hole. I'm thinking once will be enough. It was for me.
Brad Vietje
Well, now... that's different.
Brad Vietje
Hmmm....
If there's a "hole" like one from boring bugs or a nail or electric fence wire, I use air.
If there's a bark inclusion, it depends on where it is, and what the bowl is intended to be used for. If it's an artistic sorta piece, then probably nothing again; if its a functional salad bowl, I'd use either used coffee grounds (don't sacrifice any that haven't made you a cup of coffee!), or "bark dust" from sanding the bark of the tree or piece of wood in question.
But you asked about cracks from the drying process, which is a whole 'nuther thing indeed.... Those bowls I throw in the firewood pile, or in the "bone yard" to be cut up and used for something creative at some future date (which may never come, so they will probably head for the woodstove).
Not to put too fine a point on it, Avalon, but I take great care to avoid any cracks or checks, and generally I won't put my name on anything that has cracked enough that I'd need to fill it. Three possible exceptions would be spalted wood, where if the cracks after being glued look like additional black spalt lines that might be OK; certain end grain hollow forms, in which the cracks could add character, or be highlighted to some artistic affect -- maybe even widened and featured; and the small cracks around the pith near the rim of a crotch bowl with one or more "hearts" passing through the side of the bowl. I think those are the only cracks I've bothered to fill.
My rules of thumb only apply to me, so please don't feel you have to do what I do --just one fella's opinion, offered for free, and definitely worth what you paid for it!
Safe spinning,
Brad Vietje
Newbury, VT
Barb Siddiqui
Re: Be careful....
Barb Siddiqui
Time for a spatula and epoxy in a mixing bowl. I've no desire to touch the stuff.
