ADVERTISE HERE - FREE TRIAL
Paper Towel Marks
Paper Towel Marks
Paper Towel Marks
Dave Gelnett
Here is a picture of how I put my finishes on my bowls. The bottom is the orbital sander holder that spins with a jar or something tall enough to keep the bowl from touching the table top when flipped upside down. In the past I have used a clean paper towel on the jar to keep any dirt from getting on my bowl. In this picture I am trying a blue shop towel. This set up is nice to use since I can spin my work around while putting on the finish.
Problem I am having is the paper towel somehow is reacting with the finish and leaving marks but not every time. At first I thought I just did not sand it very well but notice the marks are not centered on the bowl but are off centered. (The way I set the bowl on the paper towel and did not happen on the lathe). I have tried white paper towels and blue with the same reaction.
I can fix it with several coats of finish and then wet sand to make smooth. What is a pain is after spraying the top, and letting dry for several day I need to flip over and spray the bottom. Guess what happens to the inside where the paper tower is touching? Not to sure why it happens and other times it does not.
Any advice?
Thanks
Re: Paper Towel Marks
Good looking bowl. Nice repurpose of the Sander Sitter.
I would make something out of wood like a fairly tall cone and put three nails in the top for the bowl to sit on. I spray the bottom of mine and sit them on three nails and then finish the inside.
I have a bunch of small scraps with nails in them for this purpose. If you put on light coats of finish there does not seem to be any impressions of the nails left behind. I use three because three points establish a plane and the bowls won't rock. You could use more it you are careful to make them level.
If I understand correctly, the texture...
JamieDonaldson
..of the paper towel is what you sometimes see in the base, right? The degree to which the lacquer is dry and hard varies greatly, and the added weight of the bowl is contributing to the texture you're finding in the base. I have a piece of glass that I sometimes place on my spray stand to eliminate any such texture.
John Veerkamp
I use a mason jar, pint or quart , depending on the size of the piece.
bill Crommett
My finishing stand has a couple of triangles made from old Band-saw scraps with the teeth up.
Barb Siddiqui
Barb Siddiqui
Try pounding some nails through a square of plywood and use the points up to support the workpiece. Spray the bottom, dry, then turn it over to spray the inside and rim. If you want it to turn, make a simple lazy susan to rest under the plywood square. The nail points, if sharp and small, won't mar most finishes.
Deft lacquer is very soft. It takes days to dry hard. I switched to local commercial brand and my problems like you are having went away. The other option of course is to change to something like wipe on poly
Betty Scarpino
Betty Scarpino
I've had something similar happen in the past, so my guess is that you are creating enough overspray, such that it floats to where the paper towel is touching the wood and this is what is leaving a mark on the surface. Next time, try spraying so that overspray doesn't float up and inside of the bowl (if you are spraying the outside), or conversely, float down and settle at the bottom where the paper towel is touching the bowl (when you are spraying the bowl's interior).
Or of course, you could simply eliminate the paper towel by using one of the methods others have suggested.
Dave Gelnett
Thanks all, I need to make a few bowls now to try all the advice.
Dave Gelnett
John are there any spray cans that you recommend?
Craig Daymon
I put toothpics in a sponge or piece of foam. Or, for larger projects (typically furniture), I have drilled holes in a piece of melamine and put shaker pegs in the holes. Both toothpics and the pegs being wood items, I don't have to worry about any undesirable reactions with metal.
