Burl, what to do with it?
Alan T.
Hi All,
This myrtle burl has been sitting around for a few years and is about 11" diam. and 2.5" min thickness on one side and 6" on the other. What would you do with this burl. Since I've never worked with a burl before I'm stumped on what to make with it. I've done lots of bowls and some hollow forms though. Any suggestions appreciated. Thanks.
Re: Burl, what to do with it?
Lyle Jamieson
Lyle Jamieson
The possibilities are endless. Two things come to mind that I have done often. One, is to make a natural edge bowl. Put it between centers and get the axis so the high points of the natural edge are parallel to the table when done. This will likely mean you will have to chainsaw a wedge off the bottom to get it to run near balanced for roughing. Id do a shallow gourd or calabash shape with the edge of the bowl closed in a bit to accentuate the grain and color. Second option would be to do two hollow forms. Look at the last photo and make a chainsaw cut on a line down the middle of the bed. Now you have a big and small HF. The smaller half could even be cut again in two pieces to make two shorter vessels. The chain saw cut will reveal a ton of info to give you more ideas on axis and orientation.
Aage Rendalen
Natural edge bowl
Aage Rendalen
Given the disparity in thickness, the obvious--to me--option would be to do a natural edge bowl. Mount the burl on a spur drive with the top as flat as possible. If you haven't tried it before, you might want to look at a couple of pictures I've posted before (below)
Give it to me..............NOT!!!!
Dick Wilson
:D
Re: Natural edge bowl
Alan T.
Thanks Aage, I'm not sure I get it after looking at the pics. Is the verticle line you drew in the top edge of the bowl? Are you just using the chuck to drive the piece? What's the part that comes off the tail stock? Sorry for all the ??? but I'd really like to get this right. Alan
Aage Rendalen
Aage Rendalen
Alan, Lyle put it this way:"Put it between centers and get the axis so the high points of the natural edge are parallel to the table when done." The line I drew on the blank was for a demonstration I did. I lined up the blank so that the high points (especially)--facing the church which has a spur drive in it--are on a line. What you see on the tailstock end is simply the tail end of the uneven blank. Read Lyle's explanation. He suggests you remove some of the off-center wood at the bottom to get the blank to run more evenly. Sometimes you have to, sometimes you don't.
Aage Rendalen
correction
Aage Rendalen
Looking at my own picture again, I see that in this case I've line up the LOW points, not the high points.
Re: correction
Alan T.
Thanks so much for all the help; I'll give it a try and see what happens.
