A tool I have yet to see.....
robo hippy
Just curious, but after having to get back into sanding out a lot of bowls for an up coming show; I already sit in an engineers/drafting table chair for sanding, and holding up the drill for sanding the bowls is wearing after a while. I was thinking there should be an articulated arm for mounting our drills on for sanding. Probably a universal joint of some sort, 2 arms, no banjo/tool rest. Been thinking about it as I watch the drill move through all the different angles to get my bowls sanded out. Should be possible........
robo hippy
Re: A tool I have yet to see.....
Keith Tompkins
Keith Tompkins
Hi Robo, Necessity is the mother of invention, they say. That helps explain the explosion in new tools and techniques in turning. Go for it!
Stuart Johnson
What about a bungee cord or spring that is just strong enough to hold the drill but easily stretched. Fasten it to the ceiling at a height that is just right for you to move around. The cord takes the weight but you can easily move up or down. I think something along this line is used in auto plants.
Ace Foster
Remember the old belt-driven dental drills? Blow that mechanism up by a factor of four or five and Bob's your uncle.
Bart Leetch
Kinda like a Robo Arm Oh wait a minute you already have one of those.
Bungee cord is your friend. When you get it set up post a pic.
Alan Zenreich
Alan Zenreich
Sounds like a candidate for an adapter attached to a Monster articulated hollowing rig arm.
I've considered making just such an adapter for a Guinevere inflatable domed sander on a flexible shaft.
An articulated arm like the monster tool or elbow tool was exactly what I was thinking also.
Stuart Johnson
The problem I see with this type of system is you only have one plane (forward and backward) for movement. You also need to be able to move up and down.
I saw a TV show about a company that makes a Exoskeleton suit for workers. Basically It was a robot external skeleton that the worker or soldier got into. The suit sensed his movement and added enormous strength. The wearercould pick up and move several times what he normally could. This thing was in development and was obviously very expensive, but if you could find a reference to it and check out the arms you might get some ideas that would apply to what you want to do.
Alan Zenreich
Alan Zenreich
Stuart,
If the bowl is turning, why would you have to move up and down (as opposed to in and out / left and right)?
Use a Flex Shaft Rotary tool
Jennifer Indy.USA
Try putting your sanding disc in a flex shaft tool like a B
Foredom. Its easy to control and you can sit right there at your bench or wherever you're comfy.
Jen
robo hippy
Although I have never tried a flex shaft, I wouldn't think they would handle heavy duty sanding, and would lose considerable power over the length of the shaft. My first thought was like the Monster, or a new one I saw from JT turning tools at the Symposium which is more heavy duty than the Monster. I have sanded out 60 plus bowls in the last few days, and in watching the paths and angles that I take with the sander/drill, I am thinking in terms of a robotic type arm that would have zero gravity with the drill in it, and have to pivot through at least half a sphere. Seems more complex the more I think about it. Eventually.......... Food for thought while I am sanding. Big show next weekend. Thanks for the suggestions.
robo hippy
have you thought about going with air and a light weight sander like the Grex. I have onlly used mine a couple of times because my air compressor is too small but it works great and is very light. The only draw back I see is the noise but a set of headphones would stop that.
I do have a new (to me) compressor but I have to install a larger 220 line to the shop to be able to handle that , the bigger dust collector I'm going to upgrade to and my new (again new to me) Lincoln welder.
Stuart Johnson
Forget the Monster type system, take on an apprentice.
Stuart Johnson
Just for complete control of the sander.
Alan Zenreich
Alan Zenreich
Stuart,
I don't understand your comment about complete control of the sander. Maybe I'm missing something.
When using an articulated rig for hollowing, doesn't the rig give you very precise control over the positioning of the cutter?
Granted, hand held hollowing gives you more flexibility in changing tool presentation, but I dont think this applies to sanding.
When using my Grex sander, it might -feel- nice to me to move the sander all around the inside of the bowl, but do I think it accomplishes any better sanding than if I consistantly repeated a single trajectory? Nope.
With the disk spinning, and the bowl spinning, any given point on the bowl is coming around several hundred (or thousand) times a minute, and can be reached effectively, so the disk can be moved about a simple, on-center horizontal axis and cover then entire surface.
The big decision, as I see it, is the direction of spindle rotation.
I'm not advocating this approach... I'm just not seeing any downside, if someone wants to tool up for it, as I don't see any loss of useful tool control.
Stuart Johnson
Alan, I don't think you are missing anything. I'm just thinking how I do my sanding whether with the Grex or drill I move all over the place. Back and forth plus right and left is probably all that is needed. What about swiveling to go around curves. Wouldn't that also be needed?
I think it might be an idea to follow up on especially if a large number of items are to be sanded in a production mode. Somewhere there is a video showing a bowl factory and if I remember right they use dedicated machines for sanding rather than on the lathe.
robo hippy
As I said in responce to Jorge's response above, a pneumatic drill/sander keeps the compressor running non stop.
With a simple 1 curve bowl, straight horizontal movement would work, from center to the rim. For me, I tend to move in an arc from the center out, and below center. Inside, I am on the top side of the disc, and outside, I am on the lower side of the disc. When I am sanding an ogee, things change on the outside as I tend to rotate the drill handle up. It makes for compound miter type holding, if that makes any sense.
Hmmm....... Maybe a padded articulated 2 piece arm.....
robo hippy
Alan Zenreich
Alan Zenreich
Stuart,
I agree that swiveling the head would be useful... depending on the thpe of sanding head being used.
Adapt a Centripital Sander?
charlie belden
Why Power Sand? If the piece is spinning already, and you don't want rings of scratch marks, centripital sanders that let the spinning bowl spin the sand paper have been around for a while to solve that problem. If you've got one - and a Monster or MiniMonster, seems easy enough to adapt to one of them. AND, you can adust the horizontal angle of the pad.
