Q&D Steady Rests
charlie belden
The President's Challenge for tonight's turning club meeting is TREMBLEUR - in english TREMBLERS - quite appropriate for California.
I've learned to turn long and thin ( if 1 1/2" to 2" can be considered "long"). But turning long and thin - between to short but FAT requires some way to support the FAT end so it doesn't start wobbling around - and snapping the THIN.
I saw a quick and dirty way to make steady rests that use string - in this case dental floss - to to dampen the FAT end's wobbling while you turn the THIN. Probably wouldn't work as well with larger, longer THINs with proportionately fatter FATs - but for littler stuff these things work great and can easily be made from scrap ply.
From chuck to tip what you see is a tad over 8 1/2". Ultimately this little trembleur will be about 10 1/2 to 11" tall.
Try it - you'll like it.
