Three new ones....
Three new ones....
Mike Stafford
Three new ones....
Mike Stafford
I have turned these three boxes in my unstructured free time before and after work. :b .... also before and after heat. :b
The first is my first box in persimmon. This wood was very hard and very old. I can see why it was used for the wooden heads on golf clubs. 2 1/2" tall and 3 1/2" in diameter.
The second box is turned from some blue gum eucalyptus. This is a wonderful wood to turn and finish. 2" tall and 3 3/8" in diameter.
And lastly is a box turned from verawood. This is the typical green cast of verawood which is very hard and dense. 2" tall and 2 3/4" in diameter.
All comments appreciated.....
Re: Three new ones....
Very nice!
David Walser
Mike,
These are very nice. I can't tell from the photos. Is the bead part of the lid or the body of the box?
Mike Stafford
Re: Very nice!
Mike Stafford
Thanks David. In all three instances the bead is part of the body of the box.
I do make boxes with the bead the other way around in reverse.... :b
Steven Antonucci
The third one is my favorite
steven antonucci
Not sure why, but it stands out from the other two...
S
Mike Stafford
Possibly because of dark chatoyance...
Mike Stafford
Who is related to Dark Helmet.......of Spaceballs fame.
You may not be old enough to remember Spaceballs but my son loved it and we watched it many, many times. ;)
Steven Antonucci
Not only remember it, but saw it in theaters!
steven antonucci
Rick Moranis as Dark Helmet...
Classic
S
Very Nicely done once again....
jake Niedling
I really like the color in the grain, are all of these end grain boxes? Also, what is your method or tool for shaping the ogee shaped top? I have tried this a few times and seem to get some streaking which show up after sanding. I assume it is coming from the heel of my gouge. Appreciate knowing your basic approach to this lid shape.
Enjoy seeing your boxes.
Jake
Mike Stafford
Re: Very Nicely done once again....
Mike Stafford
Jake, thank you. They are all end grain work.
Yes, if you follow the adage "ride the bevel" you will almost certainly end up with some burnished areas that are very difficult to remove because the end grain fibers are compressed. Two things I learned is to "glide on the bevel" by not pressing hard against the wood. If the end of the tool is really hot after you cut you are probably pushing too hard. The other thing is to relieve the bevel so that the heel is not as pronounced. Make sure your tool is really sharp so that it stays in the cut with minimal pressure. If you have to force it at all the tool is dull.
Oh, there is one other possibility. If the bevel is longer I have found that the bruising is more likely to occur. That is why I have ground my gouges for end grain work at somewhere around 50 degrees, probably a little less than 50 in practice.
Very nice...I need to get a piece...
of Verawood. My first granddaughter is named Vera. I see a keepsake coming.
Where does one get verawood?
Those are gorgeous boxes.
Thanks, Mike!
David Walser
Mike,
Thanks for the reply to my question. I've been to your website (in the past) and I recalled seeing that sometimes you put a bead on the body of the box and other times the bead is on the lid. (And, IIRC, some boxes are not adorned with beads.) I've printed out pictures of several of your boxes to use as inspiration when I'm in the shop. I really appreciate the resource.
One more question, if you'll permit: Why would you put the bead on the body rather than on the lid (and vice versa)?
Roger
Mike,
What are the finishes used on these boxes? Beautiful as usual. Thanks.
Roger
Paulo Marin
Fantastic lines and beautiful details.
Congratulations Mike... I wish I had the time to go turn with you :)
Thanks, that is what I suspected....
jake Niedling
Dick Hines
Dick Hines
Nice work Mike. You will have to do another book at this rate.
Mike Stafford
Mike Stafford
Hi Roger and thanks for the comments.
I am using a thinned brushing lacquer for most of my boxes these days. I thin the lacquer about 50% and apply it with a paper towel and carefully even the coat and wipe off the excess before it dries. Then I steel wool between coats and apply some Renaissance wax.
Re: Thanks, that is what I suspected....
sharp tools and light bevel pressure. That being said I have been grinding my main bevel shorter and shorter over the last few years. I used to round over the shoulder where my main bevel meets the secondary bevel. With this short main bevel I don't notice the bruising from the rear of the main bevel.
I really only had this problem on bowls especially early on. Charles Alvis told me to round over the back of the bevel. I've been doing that ever since but now that I'm making the main bevel really short I haven't noticed the bruising at all.
As good as it gets! Beautiful.
Don Orr
They're all beautiful!
Greg Haugen
My favorites are the first and third, the wood grain and forms are spot on. The curves from the lid and base look to be the same, they flow very nicely. The second box is a beautiful box but the "form" of the lid has a more different flow than the base's curve, but that's a real nitpick. One thing I've found, the boxes that I have made that have been critiqued by turners for different lid portions, etc. have been the boxes that sell first in the galleries and gift shops. Go figure.
Beautiful work Mike.
Don Leydens
Re: They're all beautiful!
Don Leydens
You sure have a way with clean and flowing lines. Outstanding work as usual.
Mike Stafford
Re: Thanks, Mike!
Mike Stafford
David, the reason that I put the bead on the body is because the lid will have a convex curve/ half bead at the point where it joins the body.
When I put the bead on the lid it is at the bottom of a concave curve/half cove and sits at the join.
The beads are there to just help disguise the join. Any kind of detail at the join helps to disguise the grain mismatch that inevitably occurs when you part a piece of wood in two and then overlap part of it so the lid can overfit the body.
Boxes without beads are usually that way because I was having trouble turning a bead or the wood wouldn't cooperate or because I didn't think it was needed because it appeared that the grain alignment would cooperate. And there may be another reason as well; some days I am lazy..... ;)
