Air filters for vacuum chuck set-ups
Randy Johnson
After thinking and dreaming about it for a long time I�ve finally decided to set up a vacuum chucking system.
The main components should arrive sometime in the next few days from Packard Woodworks. I plan to manufacture the actual chucks using information and ideas gathered from many hours of net surfing and several magazine articles.
I had planned to build the air filter between the bleeder valve and the pump using pipe and the floss used in aquarium filters. Somewhere along the line I ran across the suggestion that a filter be installed on the bleeder valve as well. Inline automobile fuel filters were suggested and this seems like a good (read cheap) solution. Is anybody using fuel filters in their vacuum systems, and if so what make and part number? One that I�ve looked at will filter anything over ten microns. That isn�t small enough to keep out Giardia cysts, but I doubt the pump would care. Is it small enough to keep out dust that WOULD damage the pump over time?
