I have worn my tools down to where they won't cut anymore.... tried to use a diamond hone, but i just have to face the facts that i need to learn to sharpen.
I bought a woverine grinding jig and a veri grind attachment from someone who was getting out of woodturning and it's been sitting in a corner for a month... I downloaded the instructions so im ok with that..
but wha'ts your favorite angle for which tool (or is there a set one for each tool?) and what's the difference between blue, white, pink, grey, green, black , chartruse, teal, or polkadot colored wheels..
yes, i know.. last three arent' real.....
Re: lookit all the pretty colors! - Grinder wheels?
You raise a lot of good questions. You might spend some time watching some of the higher rated sharpening videos at: http://woodturningvideos.weebly.com/
Re: lookit all the pretty colors! - Grinder wheels *LINK*
I would recommend starting with the setting Doug Thompson uses for his tools. You can find a sharpening description on his site. www.thompsonlathetools.com This will give you a pretty good shape to the gouge and get you started.
Then watch my 2 videos which aren't complete they were put together to answer a specific question but will probably help you understand the process.
You might go to Oneway and look up the mounting directions for the jig if you didn't get those with the jig.
As far as wheels go, they all work. I started with the standard gray wheel that comes with most cheap grinders. I don't recommend them but if that's what you have they do work. They just tend to heat up the tools and clog easily so they have to be cleaned with a star wheel frequently.
White, pink and blue wheels are all designed for High speed Steel turning tools and work fine. I use the white simply because that's what I bought and it works fine. I have a blue wheel and will try it out once these wear out but it looks like that is going to be years away.
What is most important is getting the grinder running without vibration and then trueing the wheel. I use the Don Geiger wheel truing system. Oneway makes a good one. With a lot of care you can do an acceptable job of trueing the wheel using the flat tool rest and a T shaped diamond wheel cleaning tool. It's not as good as the other 2 methods but it does work if you take really light cuts.
As far as shapes go the grinds library should give you some good ideas.
robo hippy
The AAW magazine did a recent article on grinder wheels. The CBN wheels from D Way Tools at $180 are expensive, but never have to be trued, cleaned or balanced. I am still opinionated that the diamond wheels work best on carbide, and not as well on softer steels.
robo hippy
Dennis in Southern Oregon
Regarding the setting angle for the Vari-grind jig, I have had occasion to research this topic recently as part of reviews for the Woodturner. Briefly, the exact arm angle is not very important for most sharpening needs. Thompson recommends setting the top of the arm at the 4th notch of the quadrant, which yields an arm angle of about 40 degrees with respect to the gouge shaft, for both spindle gouges and bowl gouges. Kirk DeHeer, in his video, recommends setting the top of the arm at the second notch, which gives an arm angle of about 23 degrees, again for both spindle and bowl gouges. The Oneway instructions (at least in the old version that I have) recommends setting the arm in the fully closed position (about 13 degrees) for spindle gouges and conventional bowl gouges and in the fully open position (about 62 degrees) for side-grind bowl gouges.
The reason that all of these choices work for spindle gouges is that the arm angle has very little effect on the resulting shape if the fingernail is kept short (not ground back very much). The larger the arm angle, the more the sides can be ground back before folding in to make a blunt edge. Both the Thompson setting and the DeHeers setting work well for the usual fingernail lengths in common use. However, the Oneway setting is only marginally acceptable for spindle gouges IMHO. For these same reasons, even the 40 degree arm angle recommended by Thompson is not large enough to produce a really long side-grind on a bowl gouge.
I would suggest that you set the arm in the 2nd, 3rd or 4th notch for your spindle and conventional bowl gouge grinds and for short side-grind bowl gouges.
Dennis
steve worcester
All of the setup instructions in the world are just the starting point. With a Vari Grind, the notches need to be used in conjunction with the pocket distance and height. Putting a piece of wood in the pocket with a pivot point will also vary the side slope, which is also as important.
Start by putting a known good grind in the jig and with the grinder off, use a sharpie and blacken the face of the jig. Adjust the Vari Grind by hand until you can get the face and side angles the way you like them. Don't forget to think about consistent stick out either, the amount of gouge protruding from the front of the jig.
