3520b resonance
Rob Kennedy
Hi I hope someone can help I have had a new 3520b now for the last 8 weeks However it seems that when I do any kind of large bowl turning I get a vibration the bigger the cut the more vibration it happens at any speed I think I have tightened everything up as much as I can and the lathe sits on 4 concrete pads. I was wondering if I could put something between the legs and the bed to try and provide some dampening to stop it of is there something obvious I have missed? Is it my technique? I levelled the lathe very carefully and I believe its flat but I did notice that one of the legs is not quite flush with the bed. I like to turn thin walled stuff and this vibration (and noise) prevents me from doing so I really need to sort this out I have had so much trouble with my chuck and getting it to run true which I have finally sorted only to come up against this problem.
Any ideas or suggestions welcome I will try anything now to get it to work right everyone has extolled the virtues of this lathe but I seem to have been dogged with a few problems
