Hunter Hercules!!!!
Hunter Hercules!!!!
Mike Stafford
Hunter Hercules!!!!
Mike Stafford
I had a chance to try out my new Hunter Hercules on an old walnut bowl blank that was hiding in the shop. It had some bark adhering and I thought the #3 Hunter Hercules tool would get a real test truing up the blank and cutting the bark.
Well, as it turned out this old walnut blank was no challenge at all. The Hunter Hercules took all the gnarl out of this gnarly piece of wood and left a surface that was remarkably smooth and free of tear out. Even the bark was cut cleanly and left with a near polished surface Pity the poor worm that sticks his head out of those worm holes. :b Hercules will take his head right off! :D
This massive tool transmits no vibration from cuts on out of round blanks and in short order rounded up the bowl blank and cleaned the face as pretty as you please. I also used it for rounding up box blanks and they were no challenge whatsoever. Cutting with the grain the box blanks were left with a polished surface.
This tool has become my spindle roughing gouge replacement.
Re: Hunter Hercules!!!!
Don Leydens
Don Leydens
Sounds like I better start saving for a new tool!!!!
Mike I used it yesterday to rough out some oak spindles I'm doing for my dad. It makes fast work of those. I'll probably still use my roughing gouge because I like using the wings as little skews to further clean up and refine the shape. I just wanted to see how affective it is on spindles.
