ADVERTISE HERE - FREE TRIAL
Robust tool rest
Robust tool rest
Dick Hines
Robust tool rest
Dick Hines
I have a Robust comfort rest that I have used almost every day for a couple of years. Today while turning a piece I noticed the rod that runs along the top has worked loose on the right end. I am right handed so it gets alot of use.
The first 3 inches is loose. I put some JBWeld on it but don'it know if it will hold.
Anyone else had and trouble like this?
Re: Robust tool rest
Bill Turpin WNC mountains
I made a "robust" rest for the wife four years ago, out of the rest that came with her General maxi, a piece of hardened M-2 5/16" rod and JB Weld. It has worked for four years. Welding it would have changed temper of the rod.
Robust tool rest problem?
Ed Moore in SW VA
First step, call Brent English. Of course he is probably in St Paul this weekend. I am sure that he will correct the problem.
Ed
Carole Valentine
Yep, call Brent...he will fix you up. I have several and have had no problem at all.
Richard Allen
Richard Allen
The rod is epoxied onto the rest.
Dick Hines
Re:  Robust tool rest problem?
Dick Hines
I did Ed and got a recording. I expect he is at the symposium
Dick Hines
Dick Hines
If that is true the JB Weld should do the trick
Dick JB Weld will work. His early rests were glued. The newest ones were welded. I'm sure Brent will help you out. However if your anything like me I'd just stick some jb weld on it and then send an e-mail to Brent and tell him what you did just to let him know that there was a failure. I'd certainly like to know if I had products out in the market.
charlie belden
One of our turning club members had the same problem. He called, was told to mail it back. It was returned spot welded and was told that's how they're being done now.
Walt Bennett
Walt Bennett
I have one for my midi. Have used it heavily since buying it at the Richmond symposium and haven't had any problems. I believe it's a glued one. My experience with it has been good on the midi, but I'm sticking to the round bar ones for my Stubby.
Joe Herrmann
Dick: I stopped by Robust's booth at the AAW Symposium and mentioned your post to them to see what they suggested to fix the problem. They immediately said to send it back. I'd suggest that
Don Evans
I wonder if there original idea was to make it replaceable if it got a ding that couldn't be filed away?
Dick Hines
Dick Hines
I glued it with JB Weld and it is as good as new. Had to use the tool rest that came with the lathe for a while. Glad my Robust is up and running again.
Dick Hines
Dick Hines
Just talked to Brad form Robust lathes. He said they would replace to tool rest. I explaned I had glued it back and it seems OK. He told me that if I want a new one to send it back and they would replace it. I think I will stay with the JB Weld for now. I hate to be with out the rest.
It's nice to do business with a company that stands behind their product. My hat is off the Robust Lathes.
