A55 Smoothing Plane
Brainstorming: Dis-Inhibiting Exercise
charlie belden
In order for the brain to deal with the vast amount of information our senses are constantly providing it, the brain prioritizes, focusing on information relevant to a task at hand, filtering out extraneous information. Of the information it does store for possibly use, either immediately or at some time in the future, it puts that information in either short term or long term memory. When the brain needs to act, after recalling stored info it might need, starts connecting the dots as it puts together a plan of action. During that process, a part of the brain evaluates which dots are to be connected, INHIBITING some connections.
Cross the street?
Look LEFT before stepping off the curb to see if a car is coming - because it's the one that an hit you first."
(Look RIGHT also pops into your brain - but your brain inhibits using that - in the U.S. But if you go to England . . . )
The point of all this has to do with "I'm just not very creative." and Connecting The Dots.
Brainstorming is about Connecting The Dots - without the Inhibitor part of the brain getting in the way - DIS-inhibiting connections. The following example begins with something called the Stroop Test - something identifiable - a shape, a letter or a word - in a color. The goal is to identify the shape, letter or word and ignore the its color. Then change the rules so that only the color is to be identified. Inhibit one part of the information and focus on the part the rules say you're after.
It's those RULES that get in the way of Connecting The Dots in a lot of different ways, inhibiting your "creativity". Why NOT shift letters in a word Off The Line? Why not use letters as just geometric shapes, that you can flip and turn and stretch? If you want to color "SKY", why can't it be brown - or orange - or green? Who says water has to be BLUE - and fire has to be RED? Just because a sign is shaped like a STOP sign doesn't mean it has to mean STOP in all cases
As turners, we play with shapes, patterns and colors all the time. Why not lower our inhibitions and play with a LOT of ideas for using shapes, patterns and colors. They don't all have to "work" - but sometimes what initially might seem not to work - will. Connect The Dots - THEN decide if any might work.
Re: Brainstorming: Dis-Inhibiting Exercise
I'm told that some artists...
mjonesrdg
...will smoke a little pot for this condition! :O
