Latest Low Relief 3D Laser "Carved" Piece
charlie belden
Have FINALLY gotten back to playing with doing low relief 3D laser "carving" from Gray Scale images.
Here's the gray scale image that was imported into CorelDraw X3 and "printed" to an Epilog laser
"printer"
Here is a photo of the piece after laser "carving" (Left) and after it was then sandblasted with an airbrush "air eraser" shooting 220 grit aluminum oxide to remove the charring from the laser. I think that some more work on the gray scale image, some more experimenting with the speed and power of the laser and multiple "light passes", along with a finer grit blasting material - and some subtle low relief "carving" might be attainable.
What I'm after is to have the "carving" so subtle that it would only be noticable when lit almost from the side or almost directly above - to cast shadows. Am working on some web pages on how to import images into CorelDraw, set the Corel's center to the center of the imported image, how to set up the laser so the pattern will be centered on where you want the center to be on your piece and setting for the laser's "printer driver". Will post the url when that's done.
Questions, suggestions, comments welcomed.
BTW cool looking vase. nice work... Best regards, Ralph
