90+ out side......
90+ out side......
Dick Hines
90+ out side......
Dick Hines
Well it was 90 on the out side and 75 on the inside of my shop. Best $250 I have ever spent.
Don't like turning with the door down. I feel like I am turning in a cave. It's a cool cave though.
Re: 90+ out side......
Toney Robertson
Isn't it great!!!
I purchased a small AC unit a few years ago. I imagine it is about the size of yours and like you said it was money well spent.
Do you leave yours on all night? I am only cooling about 250 sq ft so I turn mine off and then in the morning it does not take long to cool it back down.
Richard Allen
Richard Allen
Isn't it GREAT to have a cool place to turn!?
Wood dust will reduce the efficiency of the AC very quickly. Figure out how to take the AC apart so you can clean out the gunk that will build up. If you keep the filter clean (check it daily until you get a handle on how often the filter needs to be cleaned) you can make the tear down and clean an annual maintenance task. You can also put a furnace filter in front of the air intake and replace that filter as needed (could be as often as once a week but more likely once a month).
Dick Hines
Dick Hines
The AC is at one end of the shop and the lathe is as far away as it can be. I also have a fan between the AC and and the lathe. I think I will be OK
woodspinner-Harry Robinette
Dick
I turn in the basement and it was like a cave.I installed high lumino Daylight bulbs and it was instant daylight if you want the info for these bulbs just let me know.
woodspinner@neo.rr.com
avalon
wow.. 90+.... sounds chilly to me..
it averages around 100+ inside my shop everyday now..
im in central texas.... friends thermometer said outside temperature was 111...
robo hippy
We had our warmest day of the year yesterday, it almost got to 80. Night time cools off to about 50. 80 is too hot for me. I hope it isn't too bad in Minneapolis. Not used to the mid west heat and humidity.
robo hippy
Stuart Johnson
When we remodeled the 2 car garage for my wife's sewing "shop" we had to upgrade the AC so I kept the old one for the shop. Someday I'll get around to finishing the insulation and get it installed. It'll be nice to have heat and cooling but I'm okay between 50 and 90 degrees so I won't have to run it all that much. I certainly won't look forward to the electric bill.
Ric Taylor
90?  Is that all?
Ric Taylor
That would be a cold snap in Houston.
Ric
Plus..........
Richard Jones
Dick,
Don't forget all that Virginia humidity that your AC is sucking out of that garage.
AC is the best thing since automatic transmission and round balers...................
Rich
Dick Hines
Re: Plus..........
Dick Hines
I have been turning for 12 years and just miss haveing the roll up door open. I will get used to it before long.
Walt Bennett
Re: Plus..........
Walt Bennett
That's the problem I've got. I've got to open the double-wide door too many times a day to use an AC. I have been using a couple of industrial fans that make it reasonable even up to triple digits with VA humidity. Just have to keep things under a couple lbs. in weight anchored down!
Mike Stafford
Mike Stafford
It was 97 outside my shop and 93 inside. I know it sounds insane but I can work just fine when it is hot. If it is cold I am miserable.
I have a whole house fan that keeps a nice breeze circulating through the shop and two high velocity fans behind the lathe to suck out dust and add to the air circulation.
I had a room air conditioner a few years back but it quit on me and I haven't bothered to get another. Besides I don't sweat much for a fat boy.... :b
Rich Egan
It's supposed to be a nice weekend - finally! It's been cool and rainy the past few days. Our weekend looks to be sunny and pleasant in the 70's. St Paul is just a couple hours drive northwest of me.
Rich
Dick Hines
Dick Hines
Well I do sweat for a not so fat boy. And with glasses it can be a pain in the butt.
Walt , I just like to see who is comming down the driveway. I could put one of those old bells the service stations used to use.
I also miss watching the critters that come into the yard. And my skinks and fence lizards can't get into the shop to eat the bugs that fly out of the turning wood.
Ken Oakley-Sunny St. Cloud, Fla
The temperature here in Sunny St. Cloud, FL. has topped 95, 12 out of the last 13 days.
