Lazy Susan Help Please
Dick Wilson
I have never turned a lazy susan. Just a big flat plate I suspect. I have a commission piece to do that is 15" in diameter. For those of you who have done one I need some advice. What type of mechanism is best to revolve the plate? I know that you can buy those awful looking things at Lowes but I do not want that showing. Any suggestions?? Thanks. Dick
Re: Lazy Susan Help Please
Bart Leetch
The mechanical roller bearing lazy susan doesn't have to come clear out to the edge. Your bottom wood piece should be smaller than you top piece. I have an 18" one I made this way & the mechanical part doesn't show at all.
Dick Wilson
Think I am all squared away. Thanks for the input
Dick- to make a revolving piece really .....
JamieDonaldson
artsy/crafty, turn a matched groove in a top and bottom, then use marbles to give the revolving action. A simple bolt to join top and bottom also allows adjustment of the tension that is required to rotate the pieces, and some cat's eye marbles ups the "artistic value" of the project.
Re: Dick- to make a revolving piece really .....
Dick Wilson
Jamie, I am going to talk to the client this evening and am going to see what she thinks. No matter because I will make one using marbles to go in my booth. Thanks again Jamie.
Galen Vetterick
Dick
Not sure why you worry about the looks of the metal bearings. A 3" is only about 5/16" thick and is easily hidden by the recess in the base and or top plate that is only 15". Since 3" are square you do have a larger diameter recess and allow for the screw length in the overall thickness. Only needs one hole in the base to install the final screws. Marbles going to take more death in the piece but you can control the diameter you want, but then you mess with a pivot too. Hard to allow for wear with wood races.
Lyle Jamieson
Lyle Jamieson
Dick,
I have found the metal, roller bearing sets you find at the hardware stores too "indusrtial" for lazy susans. They dont turn very easy. The lack of weight and scale of the wooden part makes for a bad match.
Go to Kmart, Wall mark, or a dollar store and find a cheap plastic lazy susan for a buck or two. They are usually about 8-9 incheqs in diameter. Cannibalise the mechanism and screw it on the bottom of your platter. Works better and costs less then the hardware set.
I typically use the 4" and 6" square bearings from Rockler.
I round the work piece off using a jig and my bandsaw. I then use my large jaws (mega jaws) and cut a recess in the top piece. I "flip it" and use my other jaws and cut the edge profile. I "flip it" again and cut the recess to a larger diameter for the bearings to fit. If I'm really "fancy" you can barely see the bottom piece.
I then cut the bottom as I did the top. I then turn the bottom - for that I usually just use the "woodworm" screw and a flat wood spacer.
I've tried the plastic bearings - but to tell the truth - the best bearings I ever found came from an industrial surplus place. They were "REALLY" smooth - and only cost $1/each.
WOODCRAFT
bob davis
