ADVERTISE HERE - FREE TRIAL
router sled thingy
router sled thingy
router sled thingy
avalon
It's probably a bit beyond my current level, but was wondering if anyone has, knows of, or ever seen a sled that you can use on a toolrest socket to hold a widget for a router...
I think that how you can do some decorative fluting and carving on vases....
i've seen one in a book that looked fairly complicated... The router was at a 90 degree from the wood, but could be pushed manually around the piece and had a rod of wood that the bit went through to keep it from
going deeper into the wood... kinda freestyle routing....
Re: router sled thingy
Re: router sled thingy *LINK*
David Walser
I've heard of turners adapting the "Drill Wizard" so it will hold a small router. Here's a link to the Drill Wizard in CSUSA's catalog for reference purposes.
Drill Wizard
I made a simple box that fits on the ways of the lathe and has a slot in the top that accommodates the router with a guide bushing. I used it to cut three dovetail slots in the bottom of a post for a candle stand and a small table. I think I still have it if you want a picture. Could be expanded to cut flutes. Needs to be sturdier than I thought. With it tall enough to rest above the piece there could be some flex in it fore and aft and that either widens the slots or make them crooked. Making the router follow a contour would be tricky.
I didn't have a photo of the fully adjustable box I mount to the bed of the lathe. It has some advantages over the Banjo mounted variety but took a whole day to build. Here are some photos. I have a couple that are just made with 1" bar stock. I use PVC spacers to center the router rest so the Dremel (or router or air tool) have the cutter on center to the work. One of them I used 1" all thread with a nut so you can easily adjust the height. I use that one for traveling demos and there are some projects where having the cutter below or above center has advantages.
I also included one of my first fluting jigs that was used off the lathe. You can build the same sort of jig to sit on the lathe bed. Make some levelers for the bottom that function as manual height adjustments to compensate for the thickness of the work. The one in the photo will only accept work that will fit the adjustment your router and bit will fit.
