Hi all I am a complete newbie so I need help. I have just ordered a lathe (Turcrafter Commander vs). Now I need help in what to buy for tools. Do I need a roughing gouge and bowl gouge and spindle gouge or is there something inbetween that will do most of the work? What size tool do I need to do detail work? In other words what is a minimum to get started? I have spindle work to do now later maybe bowls.
You will probably get a list with many varied tools. This is the list that i personally recommend for new turners:
For Spindle work:
1. 3/4" roughing gouge for turning the work round and rough shaping.
2. 3/8" or 1/2" spindle gouge
3. Thin parting tool
4. 3/4" skew chisel, preferable with rounded edges such as made by Hamlet.
Add for Bowl Turning:
5. 3/8" bowl gouge for smaller bowl and final finishing cuts
6. 1/2" or 5/8" bowl gouge for both outside and inside of bowls
7. Heavy duty round nose scraper to clean up ridges made by gouges. The scraper should be applies at an angle of about 45 degrees to make a shear scrape for best results.
One thing that I do recommend strongly is buy good quality tools. Cheap tools will make the learning process much more difficult.
I addition to the above list of tools, I recommend an 8 inch slow speed grinder with white wheels (Woodcraft sells one that works well) and a jig system to give you good repeatability when sharpening. No matter how good the tools are they are essentially worthless if they are not sharp. I personally use the Woodcraft grinder with diamond wheels from Andre Martel in Canada and the Wolverine Jig system from OneWay in Canada. For my bowl gouges, I also use the Ellsworth jig to shape the cutting end. The Ellsworth grind has a tip angle of about 60 degrees and swept back wings that can be used for shear scraping. It will turn the complete bowl inside and out.
I think that Fred's advice was right-on. Expect to pay more for this initial batch of tools than you paid for your lathe. My wife bought me my first lathe, without chisels. I had the lathe for a month(without tools) until I saved up some money. I live fairly close to Packard's. They started me with a parting tool, 3/8" spindle gouge, and 1/2" bowl gouge. That is all that I could afford. $135 plus some friction polish and pen making supplies. I now have seven lathes and dozens of tools. Also join a club if possible and get some local advice. Welcome to the VORTEX.
Earl: Fred gave some excellent advice. One other thing you might want to do is to find an experienced turner who can show you some of the fundamentals of turning, and let him show you how to use the tools you will need right off. Then follow Fred's advice and go for the good stuff as you progress.
A class (Woodcraft, Highland Woodworking, Rockler or wherever) would be a good thing. Books and DVDs can also be helpful.
I would also consider getting a bedan as a spindle turning tool. I find that it is quite helpful to me in turning spindles. I prefer a larger skew as opposed to a smaller skew - but that's me.
I agree with Fred But I was trying to think what tools I use and really would be lost without them.
And 1/8 diamond shaped parting tool. If you stumble across an old Craftsman one at a yard sale, grab it. Its the most useful turning tool they ever made. I have one I bought at Wood Craft (Not a Craftsman, I wore it out) and I use it a lot.
My 1/2" Ellsworth gouge if my go to tool for most everything. Can't stress how much use I get from it enough. If I lost it I would be on my way to get another the same day. I can do the inside and out side of a bowl with it and I use it in place of a roughing gouge. I have a roughing gouge and seldom use it.
A 1" skew with the edge rounded gets a lot of use. A half inch skew gets some use as well, It is sharpening to the angle of my dovetail chuck jaws and I use it as a scraper to cut a chuck foot.
I turn mostly bowls and need to learn more about the spindle gouges. I use my Ellsworth Gouge for spindles and it works so well for me I have not bothered to figure out the spindle gouge.
I strongly agree about the Wood Craft Grinder. I have one with the original wheels and its a work horse for sharpening lathe tools. I made my own Wolverine type system and would be glad to send a picture if you care. If you get an Ellsworth gouge you will need either the Ellsworth Sharpening jig or the adjustable one for the Wolverine system and set it up for the Ellsworth Grind. ("workHorse" may be over selling the Wood Craft Grinder. Its actually a reasonably priced (cheap) but under powered grinder. But for keeping tools sharp its entirely adequate. If you are going to regrind the shape of your tools or craft your own, get a heavier duty one such as a Baldor)
Welcome to the spinning vortex of spent dollars. I also agree with buying quality tools. I started with cheap ones many years ago and the difference is night and day. If there is any chance you will stick with this you should invest in better tools. (place a Doug Thompson plug here)
The skew is an intimidating tool but is VERY useful in the hands of a skilled user. Master the skew and much will flow from that. (This from someone who is not a master, but I have watched several people who are and what they can do with that simplest of tools is astounding.)
You can always add more tools later and there are some who truely buy into the addage "I am one tool away from greatness", but you should try to start with the fewest tools possible and master them before you move on.
Great advice so far. I agree with most, but it can be a little confusing with the conflicting info. I use my bowl gouge for 99 percent of everything I do with the exception of hollowing with my boring bar and laser system.
What comes first the chicken or the egg?? Do I buy tools and learn how to use them or do I learn how to turn first, to know what tools I need to buy?? I think the second plan works better. You will find expert turners that use a dozen tools to get the job done and others like me that keep it simple and do it all with one tool. To some extent the process you learn will dictate the tools you need to buy.
I would keep it simple. A 3/4 inch roughing gouge will turn square wood round. A good diamond parting tool will help form tenons and part wood. A 3/8 or 1/2 inch bowl gouge will allow you to turn spindles and bowls. A bedan tool will allow you to perform all kinds of jobs and a extra heavy duty scraper will allow you to turn bowls and boxes. After you become competent with these invest in others. These are the five tools I reach for every time I turn
Earl, do you have any turners close to where you live? If so ask a couple if you can come over and see what they use and try a couple of their tools.
Don't go into a store and go brain dead with all the tools. You don't need every tool on the rack. And unless you have access to unlimited monay don't buy every new tool that comes on the markey.
As for me, is some one took my bowl and detail gouges away I would have to find another hobby.
