I just picked up an 8" grinder to replace my 6" because I wanted a less shallow grind. I have a virtually new 6" Norton 3X wheel that I want to put on one side of the 8" grinder, along with an 8" on the other side. So, 6" one side, 8" the other. Is this going to cause any problems in terms of wear and tear on the machine itself? Should I just suck it up and put 8" wheels on each side? Don't really have room to keep both grinders set up.
Steve I changed to an 8" for two reasons. One was the size of the hollow grind. The other was simply it takes a lot longer for an 8" wheel to wear down to the point of needing replacement.
The hollow grind size is probably a mute point. I intend to run a test one of these days if I can figure out how to do it. When you compare the small part of the circle that we actually use for out gouges I think your probably talking about a few thousandths of an inch between the depth of 6" vs 8" If we were using 3/4" bevel it might be pretty noticeable but most of my tools have a very short bevel.
John, I have been getting some bruising on the inside of my bowls and my (sizable) gut is telling me it is because of the deeper hollow grind ( when doing a push cut). I have ground away the trailing edge which helped and I think using the shallower hollow will as well. I may be completely wrong but once I get it set up, I will let you know.
Are those the diamond wheels? I know a number of folks who love them (Bill Neddow wrote about them in the journal) but they are more of a capital outlay than I am prepared to make right now.
When researching the ultimate grinding wheel some years back, I was lucky enough to find a place here in town that made them. They told me that diamond was fine for grinding carbide, but not for most steels. Thing is that steel is softer, and will clog up the wheels, and there is really no way to clean them. Ever notice that your diamond hones don't cut as well after a while. The 3 by 8 diamond bench stones I got 15 years ago still cut, but not well. This is one point that Bill made in the article. CBN (cubic boric nitride or some thing like that) is made for grinding steel, and is mostly used for moulder blades. The CBN wheel from D Way Tools is about $180. I got a different kind, and after maybe 5 years of grinding with them, I still have at least half of the wheel left. My wheel is an aluminum hub with 3/16 inch of grinding matrix bonded onto the wheel. Already spin balanced. During the time I have had my CBN wheels, (mine cost $300 each), I would have worn out more than enough of the conventional wheels, to have them pay for themselves. For a hobby turner, not necessary, but for production work, a must have.
Steve Do you round over the bottom edge of the bevel on your gouge. This will easily cause bruising. The late Charles Alvis taught me that and it's been one of the most important lessons. Since my first bevel is now pretty short and the secondary bevel is usually not even touching the bowl this hasn't been a problem for me.
...that those compression rings, caused by the heel of a gouge, never appear until the finish has been applied! As already mentioned, grinding away much of the heel to shorten the bevel will eliminate most all of these marks.
I would agree with Reed, CBN wheels are the way to go, even if you are a hobby turner/tool junkie. Another way to look at it, from an expense point of view, the 3X wheels are basically $50.00, if you purchase the Oneway wheel balancers, for $70.00, there is $170.00 for the setup, then a bit for shipping. Of course a wheel dresser for $40.00. so now we are at $210.00. If you purchase D-Way Tools CBN wheels, you are at $370.00 for two balanced wheels which never change diameter, never need balancing, never need dressing. Now maybe I am finally learning how to freehand grind, but I swear my tools are sharper.....maybe just psychological?
