chuck issue
chuck issue
chuck issue
ronnyeelen
Hi, one of my chucks seems to have small nicks in the grooves on the sides of one of the slots that take the jaws. The result is that closing the jaws does not go fine. Strength is needed.
What can I do to get those nicks out again? Is it at all possible? Or do I need to get a new chuck body?
thanks
Ronny
Re: chuck issue
Steven Antonucci
small file or sandpaper?
steven antonucci
The nick is probably not your issue. There is probably a small burr in the raceway that you need to file down. If you don't have a file that fits, make one from some sand paper wrapped around a popsicle stick.
S
Re: chuck issue
Re: small file or sandpaper?
ronnyeelen
I will give that a try tomorrow.
Now, what is a raceway....
Re: chuck issue
there may actually be a little rise where the nick is, and as Steve said, the part on the jaw that fits in this groove may also have a burr. sandpaper on a stick should easily do the job.
Re: chuck issue
Steven Antonucci
Exactly
steven antonucci
Re: chuck issue
Blow out the dust!
Doc Green
I'm assuming this chuck has been in use for a while. If that is the case, it could be simply an accumulation of dust that is causing it to be stiff and hard to adjust. This has been my experience.
If you have compressed air, blow around the jaws and sliders as you work the jaws in and out. Run the jaws over their range of motion while applying the air.
If you don't have compressed air in your shop, can you take it to a local service station for cars and have them blow it out for you? Take the chuck key with you.
Without compressed air, getting the dust out will be more of a challenge. Remove the jaws and sliders and then use a brush or whatever to brush the scroll. Pay attention when you remove the sliders - they have to go back in reverse order to the way they came out.
Good Luck, ~Doc
Re: chuck issue
Re: Blow out the dust!
ronnyeelen
The first thing we did was clean it. So, it shines as never before.
I'll first try the sanding suggestion.
thanks
